Arithmetic progression(alternate method)
  • Thread starter Thread starter needhelpperson
    Arithmetic Method
The discussion revolves around an arithmetic sequence with an even number of terms. Participants are tasked with finding the total number of terms given the sums of terms in odd and even positions, as well as the relationship between the first and last terms.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants explore different methods to express the sums of the odd and even terms, with some attempting to set up equations based on the properties of arithmetic sequences. Questions arise regarding the correctness of their approaches and the relationships between the variables involved.
Some participants have provided alternative formulations and corrections to earlier attempts. There is a recognition of errors in initial setups, and some guidance has been offered on how to correctly derive the relationships needed to solve for the number of terms.
Participants are working under the constraints of a homework problem, which may limit the information available or the methods they can use. The discussion reflects a variety of interpretations and approaches to the same problem, indicating a collaborative effort to clarify the setup and calculations involved.
needhelpperson
in an arithmetic sequence there is an even number of term's
the sum of terms in the odd places is 440 and the sum of terms in the even places is 520, the last term is bigger than the first term by 156
find how many term's the arithmetic sequence has.
This was from a previous post, but i wanted to figure it out this way.
I tried out this problem, but i can't seem to go ne where with it.
For sum of even numbers
(a+d+a+2d(n-1))*n = 1040<------------ 2an + 2dn^2 -dn = 1040
For sum of odd numbers
(a + a +2d(n-1))*n = 880<-------------- 2an + 2dn^2 - 2dn = 880
solved the two system of equation
dn = 160
N = total number = 2n
Nd = 320
d(N-1) = 156<----------- d = 164
so solve for N using Nd = 320 = 320/164 = 1.95...
Obviously this is not correct. What did i do wrong here?
For the even sequence, you should get this
n[(a+d)+(a+d)+(n-1)2d]=1040
Solve the 2 equations, get nd=80;Nd=160; Nd-d=156; d=4; N=40.
thanks a lot, so that's where i went wrong.
Here's how I did it:
If you multiply the number of terms in an arithmetic series by the average of the first and last terms the product is the sum of the series. Therefore, the sum of the even terms is
[tex]\frac {N}{2} \frac {a_2+a_N}{2} = 520[/tex]
and the sum of the odd terms is
[tex]\frac {N}{2} \frac {a_1+a_{N-1}}{2} = 440[/tex]
(Note the sum of the odd terms is even so the [itex]\frac {N}{2}[/itex] is a whole number)
Now, [itex]a_2 = a_1+d[/itex] and [itex]a_{N-1} = a_N-d[/itex] where d is the common difference. Substitute these into the equations and subtract the two equations to obtain [itex]N d = 160[/itex]
We also know [itex](N-1)d = 156[/itex] so, dividing gives
[tex]\frac {N}{N-1} = \frac{160}{156} = \frac {40}{39}[/tex]
from which N = 40 follows.
17K
  • · Replies 17 ·
