Proof of Indicial Notation Identity: Shortcut and Results
  • Thread starter Thread starter ftarak
    Notation Proof
The forum discussion focuses on the application of the identity \(\epsilon_{ijk} \epsilon_{klm} = \delta_{il} \delta_{jm} - \delta_{im} \delta_{jl}\) to derive specific results in tensor calculus. The results include \(\epsilon_{ilm} \epsilon_{jlm} = 2\delta_{ij}\) and \(\epsilon_{ijk} \epsilon_{ijk} = 6\). Participants highlighted the importance of recognizing dummy indices and cyclic properties of the Levi-Civita symbol in their calculations. The discussion emphasizes the necessity of careful index management to avoid errors in tensor identities.
  • Understanding of tensor calculus and Levi-Civita symbols
  • Familiarity with Kronecker delta notation
  • Knowledge of index notation and dummy indices
  • Basic skills in manipulating mathematical identities
  • Study the properties of the Levi-Civita symbol in detail
  • Learn about tensor contractions and their implications
  • Explore the derivation of tensor identities using index notation
  • Investigate applications of tensor calculus in physics and engineering
Students and professionals in mathematics, physics, and engineering who are working with tensor calculus and need to understand the manipulation of tensor identities and properties of the Levi-Civita symbol.
ftarak
Use the identity
[tex] \epsilon_{ijk} \epsilon_{klm} = \delta_{ik} \delta_{jl} - \delta_{il} \delta_{jk}[/tex]
as a shortcut to obtain the following results:
a) [tex]\epsilon_{ilm} \epsilon_{jlm}= 2\delta_{ij}[/tex]
b) [tex]\epsilon_{ijk} \epsilon_{ijk} = 6[/tex]
I tried to solve that by solving the determinant [tex]\epsilon_{ilm} \epsilon_{jlm}= [\delta][/tex] but the result just became zero. or even, I tried to change i=k and j=l in the first equation but the result was zero as well. I don't know what should I do, I'm really stuck.
ftarak said:
Use the identity
This is incorrect, on the LHS only the indices [itex]i[/itex], [itex]j[/itex], [itex]l[/itex], and[itex]m[/itex] are free indices ([itex]k[/itex] is being summed over, so it is called a dummy index), so only those indices should appear on the RHS side of the identity. Instead, you should have:
[tex]\epsilon_{ijk} \epsilon_{klm} = \delta_{il} \delta_{jm} - \delta_{im} \delta_{jl}[/tex]
Start by using the fact that [itex]\epsilon_{ijk}[/itex] is invariant under cyclic transposition of indices so that [itex]\epsilon_{jlm}=\epsilon{mjl}[/itex] and hence, [itex]\epsilon_{ilm} \epsilon_{jlm}=\epsilon_{ilm} \epsilon_{mjl}[/itex], which is in the same form as your identity with [itex]j \to l[/itex], [itex]k\to m[/itex], [itex]l\to j[/itex] and [itex]m\to l[/itex]... What does that give you (show your calculatiuons)?
  • · Replies 17 ·
  • · Replies 26 ·
