What Is the Correct Locus for the Equation z(overline{z}+2)=3?
The discussion revolves around determining the locus defined by the equation z(𝑧̅ + 2) = 3, where z represents a complex number and 𝑧̅ its conjugate. Participants explore the implications of this equation in the context of complex numbers and their geometric representations.
  • Mixed
  • Participants attempt to manipulate the equation by substituting z with x + yi and expanding it to analyze its geometric representation. Some express confusion regarding the nature of the locus, debating whether it represents a circle or specific points on the x-axis.
The conversation is ongoing, with various interpretations being explored. Some participants suggest that the locus may consist of specific points, while others argue for a circular representation. There is no explicit consensus, but several participants provide insights and corrections regarding the algebraic manipulation of the equation.
Participants question the assumptions made during the manipulation of complex numbers and the implications of imaginary components in the context of real-number coordinates. There is also mention of potential typos and misunderstandings in previous calculations.
Grand
What is the locus given by
[tex]z(\overline{z}+2)=3[/tex]
where the overbar means conjugate.
After using z=x + yi and expanding the backets, one gets the equation:
[tex]x^2+2x+y^2+2iy=3[/tex]
or
[tex](x+1)^2+y^2 +2iy=4[/tex]
which is a circle crossed with the line y=0, which means that the locus is actually the points +/-1. However, the book says it is a circle.
You're correct that y=0, but you didn't solve for x correctly.
Oh yes, sorry for that, it must be 1 and -3 (if I'm not super absent-minded again).
I think that u can't just times it in the complex number when u want to find the locus.
My teacher taught me that when u want to find a locus of an equation u have to find the magnitude of unit vector of it.
Example : From question, (x+yi)(x-yi+2)=3
The magnitude unit vector of x+yi is (x^2+y^2)^1/2
The magnitude unit vector of x+2-yi is ((x+2)^2+(-1)^2)^1/2
Then we times it up and we get (x^2+y^2)^1/2 x ((x+2)^2+(-1)^2)^1/2 = 3
the result will like be x^4+4x^3+4x^2+2(xy)^2+4xy^2+4y^2+y^4=9
Ya i think i misunderstood the qeustion
I can see that it's not a circle from the equation (correct me if i am wrong)
Ya i think i misunderstood the qeustion..it is not absolude l l
or
To make it even more obvious to the reader/marker that you know what is happening, you might want to factorize y as you did with x by noting that [tex](y+i)^2=y^2+2iy-1[/tex]
I was thinking about that, but if I write it as
[tex](x+1)^2+(y+i)^2=3[/tex]
it is clear that it is a circle. So which one is actually true?
How is that a circle? The presence of i screws it up.
Your original formula, [itex]z(\overline{z}+ 2)= 3[/itex] educes, after you write z= x+ iy, to [itex](x+ 1)^2+ (y+ i)^2= 3[/itex] but that is NOT a circle in the xy-plane because, having change to [itex]x+ iy[/itex], both x and y must be real numbers. There is no point "(-1, -i)" in the xy-plane.
[itex]z(\overline{z}+ 2)= 3[/itex] gives, just as you say, [itex](x+1)^2+ y^2+ 2iy= 3[/itex] and comparing real and imaginary parts we have [itex](x+1)^2+ y^2= 3[/itex] and 2y= 0. Yes, y= 0 and then we have [itex](x+ 1)^2= 3[/itex] so that [itex]x= -1\pm\sqrt{3}[/itex]. The locus is the two points [itex](-1+ \sqrt{3}, 0)[/itex] and [itex](-1- \sqrt{3}, 0)[/itex], the only two complex numbers that satisfy the original equation.
Oh yes sorry, I screwed up big time.
so actually mentallic, was my method correct or wrong?
No not quite. As Hallsofivy has already shown, while the solutions lie on that implicit equation you've given (which I'm sure is an ellipse by the way), they only exist for when y=0, or in other words where it cuts the x-axis.
By the way, small typo on Hallsofivy's part, the solutions are (-3,0) and (1,0).
so what is the equation of the locus?
The intersection between the equations [tex]y=0[/tex] and [tex](x+1)^2+y^2=4[/tex]
  • · Replies 20 ·
