Thread Closed
Another Calc2/diff eq integral problem
Share Thread Thread Tools
Sep14-04, 07:26 AM   #1
it's a diff eq problem
dN/ds=k(250-s)
The way I'm doing it. (S=integral sign)
SdN/ds=k[S250 ds - Ss ds]
N = k[250s-(s^2)/2]+C
Not sure where I'm going wrong here, but it looks nothing like the answer in the solution manual which just jumps from Sk(250-s)ds to -k/2(250-s^2)^2+C
Thanks for any help.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Sep14-04, 07:52 AM   #2
Quote by kdinser
seems to me your answer is correct, only you gotta loose the ds on the right hand side. There should only be the integral of dN which indeed is equal to N.
How did you come to that other answer ???
Were there initial conditions given ???
µ
regards
marlon
Sep14-04, 08:39 AM   #3
The original problem exactly as it appears in the book.
Write and solve the differential equation that models the verbal statement.
The rate of change of N with respect to s is proportional to 250-s
I took that to mean that
the derivative of N, N', or dN/ds is equal to k(250-s)
So to find N, integrate both sides with respect to s, I came up with;
The solution manual goes through these steps.
(S=integral sign)
dN/ds=k(250-s)
S(dN/ds)ds=Sk(250-s) ds (shouldn't that 1/ds on the left side have moved to the right before integrating?)
SdN=-(k/2)(250-s)^2 + C
Does this make any sense? I don't see where the 1/2 is coming from or the squaring of the (250-s). Integrating k(250-s) looks about as straight forward as it gets unless I'm missing something that is happening on the left side before doing the integrations. Thanks
Sep14-04, 08:48 AM   #4
ahh, ok , got it. In the integration of k(250-s) they used a substitution. Set u =250-s. Then du = -ds and the integral yields kS(u)(-du) = -kSudu = -k*u²/2 = -k/2 * (250-s)²
This is it...
regards
marlon
Sep14-04, 08:55 AM   #5
Just got an email about this one from my prof, she said my answer is fine. The book did it as a u substitution. I just tried it and got the same answer as the book. Thanks for the input Marlon.
Haha, whenever I come up with du=ds in a substitution, it usually means I'm doing it the hard way.
Thread Closed
Thread Tools
Similar Threads for: Another Calc2/diff eq integral problem
Thread Forum Replies
Particular integral question with 2nd order diff eq'ns Differential Equations 8
Early Calc2 HW Help Calculus & Beyond Homework 2
Integral/Diff Problem Calculus & Beyond Homework 3
[Calc2] Question about convergence of series. Calculus 6
Calc2: Volume Calculus 10
