Convolution of discrete and continuous time signals
Convolution of discrete-time signals with continuous-time signals is feasible and can be mathematically expressed. Given a discrete-time signal x(nT) and a continuous-time signal y(t), the convolution can be computed by treating the discrete signal as a series of impulses using the delta function. The resulting convolution is represented as x(t) ⊗ y(t) = ∑ x(nT) y(t - nT), assuming convergence of the series. This approach effectively combines the two signal types in a coherent manner.
  • Understanding of discrete-time signals and continuous-time signals
  • Familiarity with convolution operations in signal processing
  • Knowledge of delta functions and their properties
  • Basic grasp of signal convergence concepts
  • Study the properties of convolution in signal processing
  • Learn about delta functions and their applications in signal representation
  • Explore convergence criteria for series in signal analysis
  • Investigate practical applications of discrete and continuous signal convolution in systems
Signal processing engineers, students in electrical engineering, and researchers working with mixed signal types in analysis and system design.
swuster
Not a specific question per se but...
Is it possible to convolve a discrete-time signal with a continuous-time one?
if you have x(n) and y(t) can you calculate the convolution of x and y (say, by taking y(t) for t in the set of integers or by treating each x(n) as its value multiplied by the delta function) or is there something inherently wrong about this?
A discrete-time signal x(nT), where T is the sampling period, is a special case of a continuous-time signal, as you can write
[tex]x(t)=\sum_{n}x(nT)\delta(t-nT)[/tex]
so if y(t) is a continuous-time signal, the convolution is
[tex]x(t)\otimes y(t)=\sum_{n}x(nT)\delta(t-nT)\otimes y(t)=\sum_{n}x(nT)y(t-nT)[/tex]
(you have to assume this converges).
