| New Reply |
inequality in triangle |
Share Thread | Thread Tools |
| Nov26-10, 03:12 PM | #1 |
Prove that in any triangle ABC with a sharp angle at the peak C apply inequality:(a^2+b^2)cos(α-β)<=2ab
Determine when equality occurs. I tried to solve this problem... I proved that (a^2+b^2+c^2)^2/3 >= (4S(ABC))^2, S(ABC) - area but I dont know prove that (a^2+b^2)cos(α-β)<=2ab :( thanks for your help |
| Nov26-10, 05:09 PM | #2 |
hi harry654! welcome to pf!
![]() (try using the X2 icon just above the Reply box )by "sharp angle", i assume you mean an acute angle, less than 90°? hint: where in that triangle can you find (or construct) an angle α-β ?
| Nov27-10, 03:16 AM | #3 |
by "sharp angle", i assume you mean an acute angle, less than 90°? yes :)
hint: where in that triangle can you find (or construct) an angle α-β ? oh. I know that apply π-(α+β)=γ. But i cant see in that triangle an angle α-β. I have tried to solve this problem already 3 days, but I always proved other inequality. |
| Nov27-10, 03:28 AM | #4 |
inequality in triangle![]() you know that α-β is in the answer, so you know there must be an α-β somewhere … where could you draw an extra line to make an angle α-β ? |
| Nov27-10, 03:59 AM | #5 |
I can draw paralell straight line with BC. Then i draw paralell straight line with AC. And then I depict triangle ABC in axial symmetry according AB. And at the peak B(under) I have an angle α-β. Is it OK?
| Nov27-10, 04:08 AM | #6 |
sorry, i don't understand
![]() can you supply some extra letters (D, E, …), to make it clearer? |
| Nov27-10, 04:19 AM | #7 |
OK.
We have triangle ABC. I draw paralell line p with BC and paralell line l with AC. p intersects l in the point D. Then angle DBA is equivalent with α. I depict triangle ABC in axial symmetry according AB. this triangle mark AEB.Then angle EBA is equivalent with β. And angle DBE is α-β |
| Nov27-10, 04:34 AM | #8 |
oh i see!
yes, but a lot simpler would be to draw just one line … draw CD equal to CA with D on BC … then triangle DBC has two sides the same as ABC, and angle DCB is α-β ![]() (btw, "depict triangle ABC in axial symmetry according AB" is weird … write "reflect triangle ABC in AB" )
| Nov27-10, 04:54 AM | #9 |
)[/QUOTE]sorry my english is not enough good I know :( draw CD equal to CA with D on BC ... When I draw D on BC so B,C,D are on one line... and it isnt triangle DBC so I am confused... sorry :( |
| Nov27-10, 04:56 AM | #10 |
sorry, i meant with D on AB
| Nov27-10, 05:13 AM | #11 |
oh yes.
Now, Should I compare areas of triangles ABC and DBC, shouldnt I? |
| Nov27-10, 05:35 AM | #12 |
no!!
(why are you so keen on areas anyway? you'll hardly ever need them, and certainly not here )forget about triangle ABC now just use triangle DBC
| Nov27-10, 05:55 AM | #13 |
Ok... I use cosinus law and I have equality. But I think I must something compare because I need prove inequality
| Nov27-10, 06:03 AM | #14 |
what equality?
![]() (btw, we say "sine" and "cosine" )
| Nov27-10, 06:14 AM | #15 |
Ok.Maybe dont understand me. When I use cosine law I get a^2+b^2-2abcos(α-β)=h^2
when h is DB. But I need (a^2+b^2)cos(α-β)<=2ab I now see that equality occurs when triangle is isosceles. But I try from a^2+b^2-2abcos(α-β)=h^2 get (a^2+b^2)cos(α-β)<=2ab. |
| Nov27-10, 06:47 AM | #16 |
)hint: eliminate ab
| Nov27-10, 07:28 AM | #17 |
hint: eliminate ab
I found that I am stupid... when I eliminate ab cosine law will not apply or no? |
| New Reply |
| Thread Tools | |
Similar Threads for: inequality in triangle
| Use Schwarz inequality to prove triangle inequality | Calculus & Beyond Homework | 3 | ||
| Triangle Inequality and Cauchy Inequality Proofs | Calculus & Beyond Homework | 14 | ||
| Triangle Inequality | Calculus & Beyond Homework | 7 | ||
| Triangle Inequality | Calculus & Beyond Homework | 5 | ||
| triangle inequality | Calculus & Beyond Homework | 1 | ||
