HELP Extremely difficult calculus problem
  • Thread starter Thread starter don1231915
    Calculus
The discussion revolves around a calculus problem focused on optimizing the dimensions of a cuboid that fits within an elliptical structure. The original poster seeks to maximize the volume of the cuboid while adhering to specific constraints related to the dimensions of the structure.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the relationship between the cuboid's dimensions and the constraints imposed by the elliptical structure. There are mentions of using differentiation and exploring local maxima, as well as questioning the original poster's understanding of the problem setup.
Several participants have provided insights into the mathematical relationships involved, including the use of equations to define the constraints. There is ongoing exploration of different methods to approach the problem, with no clear consensus on a single method being favored.
Participants note the original poster's edits may have led to confusion regarding the initial question. Constraints such as the maximum height relative to the width of the structure and the minimum height of the rooms are also highlighted as important factors in the discussion.
don1231915
HELP!Extremely difficult calculus problem! Optimising to find the maximum volume.
d(x)
If you assume the cuboid's lateral dimensions to be (x,y), the point of contact at (x,y,z) with the ellipsoid will give you its height. Then given the various constraints you have - find (x,y) that maximizes the volume... There will be several points at the ends of these intervals that could be the maximum, but you have to look for local internal maxima as well.
where is the question? i don't see it
Looks like the OP edited it and deleted it by mistake...
I have a upside down looking curve structure (½ ellipse). It has the following specifications:
The building has a rectangular base 150m long and 72m wide. The max height of the structure should not exceed 75% of its width or be less than half the width. And the min. height of a room in the building is 2.5m
The height of the structure is 36m
so acc. to my graph: http://imageupload.org/pt-112919260786.html
The equation is y= sqrt (1296-x^2)
How to find the dimensions of a cuboid with max. volume which fits inside this curve?
PLS REPLY
that method is really complex, i mean is there any other way rather than using 3d graphs?
Like, differentiating or something
also, isn't the local maximum just (0,36)
Thank you so much for helping me!
If you let the axis of the ellipse be (a,b,c) and the cuboid have the size (2x,2y,z) - the point of contact is defined by
[tex](x/a)^2+(y/b)^2+(z/c)^2=1[/tex]
Maximize x*y*z with this constraint.
(x,y)=(0,36) would have zero volume so, no, that is not a maximum, local or otherwise.
Cool, so that would just be x+y+z= 18, i can't download autograph (the only best 3d graphing software). I am super curious about how the graph of this might look like. Any ideas about the software?
That is a really in depth explanation and sounds difficult too. I actually wanted to keep it simple. So what I did was found out the volume
V= 300xy
i plugged in y with the equation of the ellipse (y = sqrt(1296-x^2)) and then differentiated and found x and therefore y and also the max volume.
Thank you so much for your help!
I have one final question, I know the max volume of the cuboid. I just need to know the volume of the structure (i.e. curve).
I know how to find the area using the integral but would that be the same as volume??
Thanks again
