New Reply
Speed of a Wave (Literal Wave)
Share Thread
Jan25-11, 08:22 PM   #1
A jetskier is moving at 8.30 m/s in the direction in which the waves on a lake are moving. Each time he passes over a crest, he feels a bump. The bumping frequency is 1.17 Hz, and the crests are separated by 5.30 m. What is the wave speed?
Jetski's Speed = 8.30m/s with the waves
ƒ of waves= 1.17
wavelength = 5.30m
2. Relevant equations
v = (wavelength)ƒ
3. The attempt at a solution
when i tried the equation above i got an answer of 6.201m/s which turned out to now be right. What am i missing here?
v = ƒ(wavelength)
v = (1.17)(5.30)
v = (6.201m/s)
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Jan25-11, 10:31 PM   #2
Recognitions:
Homework Helper Homework Help
The waves are moving forward at the same time that the boat is, so the frequency of the bumps that the skier feels is not the frequency of the wave.
I suggest that you draw a diagram showing a wave at some starting time (zero is a good number), with the jetski at a wavecrest. The jetski will hit the following wavecrest at a time consistent with the given bump frequency. So, draw another wave below the first but shifted over to reflect that the wave has moved during that time interval. See if you can't work out the wave speed from there.
Jan25-11, 11:00 PM   #3
Homework Helper 2012
Recognitions:
It is easy to solve this problem by using the relative velocity of the skier with respect to the waves. If the velocity of the waves is V, the relative velocity of the skier is 8.3-V (m/s), as they move in the same direction. You can imagine a standing wave pattern with crests 5.30 m apart. The skier travels this distance with its relative velocity in 1/f time (f is the frequency of the bumps). Just use the relation "distance = speed times time".
ehild
Jan26-11, 06:51 AM   #4
Quote by ehild View Post
ehild
Why would it be 8.3 - V if they go in the same direction? wouldn't they add up? Also how does the skier have two relative velocities? (8.3 - v) and (1 / ƒ)
I'm still not getting it.
Jan26-11, 07:26 AM   #5
Recognitions:
Imagine you sit on a train and another train travels beside you with the same velocity Does it seem moving at all?
The skier moves with velocity v(rel)=8.3-v during a time interval T=1/f. The distance travelled is 5.3 m.
ehild
Jan26-11, 08:01 AM   #6
Okay, yeah that makes sense now, i don't know how that didn't click before, thanks for your help man.
New Reply
Similar discussions for: Speed of a Wave (Literal Wave)
Thread Forum Replies
High speed sine wave to square wave converter Electrical Engineering 14
Does phase speed = wave speed, for a wave on a string? Introductory Physics Homework 0
Finding the relationship between wave speed and tension in a standing wave Introductory Physics Homework 0
Wave eq., two real fields with interaction, wave speed. General Physics 1
How does the V shape of a shock wave depend on the speed of the wave source? Introductory Physics Homework 1
