Physics Hwk. Problem: Center of Mass
The discussion centers on a physics problem involving momentum conservation during a rocket firing from a spaceship. The spaceship, initially moving at +250 m/s with a mass of 2.0 x 10^6 kg, fires a 1200 kg rocket, bringing the spaceship to a halt. The correct application of the momentum conservation equation reveals that the velocity of the rocket is approximately 104.17 m/s. Users are advised to ensure consistent units and double-check calculations to avoid errors.
  • Understanding of momentum conservation principles
  • Familiarity with basic physics equations, specifically for momentum
  • Knowledge of unit consistency in calculations
  • Ability to solve algebraic equations
  • Study the principles of momentum conservation in closed systems
  • Learn how to apply the momentum equation in various scenarios
  • Review examples of rocket propulsion and its effects on motion
  • Practice solving physics problems involving multiple objects and their interactions
Students studying physics, educators teaching momentum concepts, and anyone interested in understanding the dynamics of rocket propulsion and motion in space.
shawonna23
With the engines off, a spaceship is coasting at a velocity of +250 m/s through outer space. The ship carries rockets that are mounted in firing tubes, the back ends of which are closed. It fires a rocket straight ahead at an enemy vessel. The mass of the rocket is 1200 kg, and the mass of the spaceship (not including the rocket) is 2.0*10^6 kg. The firing of the rocket brings the spaceship to a halt. What is the velocity of the rocket?
I used the equation vcm=m1*v1+m2*v2 divided by m1+m2. The answer I got is wrong. Am I using the right equation? Please Help ASAP!
The initial mass of the rocket, spaceship combination is 2001200 kg and its speed is 250 m/s so its momentum is 500300000 kgm/s. The momentum of the spaceship after firing the rocket is 0 so its momentum then is 0. The momentum of the rocket is
1200vr and that must equal the original total momentum:
1200vr= 500300000.
I have no idea why you are using "vcm" since the problem does not say anything about the center of mass!
Yes, you are using the correct equation for center of mass. However, it seems like you may have made a mistake in your calculation. The final velocity of the spaceship after firing the rocket should be zero, as it comes to a halt. This means that the equation should be set up as 0 = (2.0*10^6 kg)(250 m/s) + (1200 kg)(v2) / (2.0*10^6 kg + 1200 kg). Solving for v2, the velocity of the rocket, gives a value of approximately 104.17 m/s. Double check your calculations to see if you made any errors. Also, make sure to pay attention to the units and use consistent units throughout your calculation. Good luck!
  • · Replies 17 ·
  • · Replies 23 ·
34K
10K
