Finding the Foci of a Quadratic: Working with y^2=1-2x^2
  • Thread starter Thread starter wat2000
    Quadratic
The discussion revolves around the equation of a quadratic, specifically in the form of an ellipse represented by y² = 1 - 2x². Participants are attempting to rewrite this equation in the standard form of an ellipse, x²/a² + y²/b² = 1, to find the foci and related properties.
  • The original poster attempts to rearrange the equation but expresses uncertainty about how to proceed without altering the equation's integrity. Some participants suggest comparing coefficients to determine the values of a and b, while others question whether to manipulate the equation to maintain the constant term.
Participants are actively engaging with the problem, exploring different interpretations of how to align the given equation with the standard form. There is a focus on understanding the relationship between the coefficients and the parameters a and b, with hints provided to guide the reasoning process.
There is a concern about maintaining the equation's structure while attempting to express it in a different form. Participants are navigating the constraints of the problem setup and the implications of their manipulations on the equation's validity.
wat2000
y^2= 1- 2x^2
im supposed to put it in x^2/a^2 + y^2/b^2 = 1 to find the foci and so forth.
when i try to set it up i get 2x^2 + y^2 = 1. I am not sure where to go from here. if i multiply or divide to set the problem up properly the 1 will change and my equation will be messed up. can someone show me what my next step is?
Try match the equation for your particular ellipse, 2x2 + y2 = 1, with the general equation for an ellipse which you have also written up. What value must a and b have in order to match your equation?
should I put everything over 1? so that the 1 stays the same?
I think you misunderstand. If you compare the equation 2x2 + y2 = 1 with x2/a2 + y2/b2 = 1, then what value must a and b have for the two equations to have the same set of solutions, that is, for them to express the same ellipse?
Hint: 2x2 must be equal to x2/a2 for all x, and likewise y2 must equal y2/b2 for all y. Solving these two equations will to get you a and b, and from these you should be able to derive the position of the loci (you may want to look in your textbook on how this position is related to the value of a and b).
