Finding steady-state solution to heat equation with boundary conditions
9 replies · 4K views
yaya10
Hello
I need help with this heat equation
I need to find steady state solution please help me
I ve tried but I could not get it.
http://www.alm5zn.com/upfiles/m0w00932.jpg
I ve got C= Cx/2 +ax+b
but i could not apply the boundary conditions?
any help would be apprecited
Thank you
Your equations are simple enough that you could just post them here instead of making everyone open a gif on imageshack.
Anyway, there are two obvious things wrong with what you did:
1. What happened to the D and k that should be in your steady state equation?
2. C is the independent variable and you are treating it like it is a constant. It depends on x even in the steady state so its antiderivative isn't Cx.
So correct your steady-state equation and solve it as a second order constant coefficient equation.
A "steady state" solution is one that does NOT depend on t. That means that the partial derivative with respect to t is 0 and the partial derivative with respect to x can be treated like an ordinary derivative:
[tex]d\frac{d^2C}{dx^2}- kC= 0[/tex]
That's a "linear second order differential equation with constant coefficients", probably the simplest kind of differential equation. Do you know how to solve such equations? What is the "characteristic equation"?
hello LCKurtz,
sorry about the image but I thould it would be much describable this way.
thank for your help
HallsofIvy
thanks for being here
I ve got this
first I divide them by D to get K/C then I called them a=K/c
characteristic equation:
(m^2)-a=0
m^2=a---->>> m=-sqrt(a), sqrt(a)
--->C(x)= c1*exp(-sqrt(a)), and c2*exp(sqrt(a))
[tex](m^2)-a=0, m^2=a \mapsto m=-\sqrt{a},\sqrt{a} --->C(x)= c1*exp(\sqrt{a})+ c2*exp(-\sqrt{a}).[/tex]
Your characteristic equation comes from assuming solutions of form exp(mx), so your equilibrium solution needs to look like:
[tex]C(x)= c_1\exp(\sqrt{a}x)+ c_2\exp(-\sqrt{a}x).[/tex]
But now consider the boundary conditions (which really dominate the equilibrium solution for this problem anyway).
thanx for your help
Now I substitue the boundary conditions I got
C(infinty,t)= c1exp(infinity)+c2 exp(infinty)=0
-->> c1+c2=0-->>>>> c1=-c2
is that true ?!
I am sorry for bothering you guys
i need to learn
thanks again
yaya10 said:
thanx for your help
That isn't how you write limits. Think about this. If you have a function of the form
f(x) = Cekx+De-kx what happens to each term as x → ∞? That should determine one of the constants. And you also have x → -∞ to think about.
the lim when x → ∞ = ∞
so from the equation you gave
D wil be zero and C is infinity so we have got D=0
and then
when → - ∞ = 0
we have got
C will approach zero and D is infinity.
So C=D+0
I hope this is correct.
Limits are hard for me so I reall hope I have got it right.
Thank you
and then
when → - ∞ = 0
we have got
So C=D+0
Thank you
The point is that you are given in your problem that as x → ±∞ the limit is zero. So you should be able to argue that the only way that could happen is if both C and D are zero.
