Can Vacuum Pockets Make Objects Float?
  • Context: High School
  • Thread starter Thread starter rollcast
The discussion explores the concept of whether objects containing pockets of trapped vacuum can float, similar to how objects with air pockets achieve buoyancy. Participants examine the implications of density, material strength, and the feasibility of creating such objects.
  • Some participants propose that an object with trapped vacuum can float if its overall density is lower than the surrounding medium.
  • Others argue that the weight of the material needed to contain the vacuum may negate any buoyancy gained from reduced density.
  • A participant suggests that a strong enough material could theoretically create a buoyant chamber, but it would likely be delicate and prone to deformation.
  • Hydrogen is mentioned as a potential gas for buoyancy due to its lightness, but concerns about its combustibility and cost are raised.
  • Heated air is discussed as an alternative that could produce buoyancy effects at a lower cost, with reference to hot air balloons.
  • Helium is noted as a safer alternative to hydrogen, with questions about the material properties needed for a vacuum-containing balloon, including non-porosity and strength to withstand external pressure.
  • Participants discuss the structural properties of materials, referencing the compressive strength of eggs as a model for potential designs.
Participants express differing views on the feasibility of creating buoyant vacuum pockets, with no consensus reached on the practicality or effectiveness of such designs.
The discussion highlights limitations related to material properties, the need for specific strength characteristics, and the challenges of maintaining a vacuum without structural failure.
rollcast
Would it be possible for an object with pockets of trapped vacuum space be able to float just the way air pockets do as it is less dense?
Thanks
Yes.
A simple explanation, the ability to float relies on a difference in density. As long as the object with a vacuum internally has a lower density than the surrounding medium, it will float.
Thanks
Be aware that such a scenario requires material to contain the vacuum.
That material has weight.
I'll leave it to you to go from there.
Thanks light bulb moment, the weight of the material need to resist the compressive forces around the vacuum far outweigh any reduced density you achieve from it
Good job!
Yep. In theory, with a material that is strong enough you could create a chamber using so little material that it is buoyant. (Or more accurately, its total mass is less than that of the same volume of air.)
Problem is, it would surely be extremely delicate. The slightest bump would likely cause it to deform and implode.
This is why hydrogen makes such a great runner-up. It's the lightest element known that can provide an atmospheric pressure so that the walls don't even need to be rigid. Just that darn combustibility...
And cost. Hydrogen is expensive, and leaks through common membranes.
Heated air seems to produce similar bouyancy effects with a reduced TOTAL cost?
Just asking... not sure.
Heated air becomes less dense, causing it to rise in the air. This is how hot air balloons work. You just have to heat it which CAN be less expensive.
Helium is the next lightest and has the nice feature of not being so flammable!
Out of interest does anybody know how we could work out the necessary material properties of a vacuum containing balloon?
You mean to contain the vacuum or its lift/bouyancy
Well, it must be non-porous, so that there is no gas transport across it. It must have sufficient compressive and shear strength (I think those are the right terms) to withstand the pressure difference of 15 psi (1 atm) pushing from outside to the inside. "Balloon" seems like the wrong word, since balloons have an opposite pressure differential ...
Good ideas. I was wondering what physical properties our material would need in terms of tensile strength etc. I use the word balloon only in the sense of if it would be possible to make a buoyant vacuum pockets
You can start by examining how a common egg gets its compressive strength. It is structurally equivalent to a stone archway with no endpoints.
The standard experiment to show that this is likely to be true with normal materials is to put a little water in a good-sized tin can (say a 2-gallon gas can) with a small top, heat the water until it has all become steam and driven out the air, and then close the can and watch the can implode.
  • · Replies 50 ·
  • · Replies 18 ·
