Does a Thevenin Equivalent Circuit Accurately Predict Power in Variable Loads?
The discussion centers on the accuracy of the Thevenin Equivalent Circuit in predicting power consumption for variable loads. Participants confirm that the Thevenin Equivalent simplifies complex circuits, allowing for easier calculations of power. It is established that the power calculated using the Thevenin Equivalent may differ from that in the original circuit due to the configuration of the variable load, particularly when it is in parallel versus series. Testing both configurations is recommended to observe the differences in power consumption directly.
  • Thevenin's Theorem
  • Circuit analysis techniques
  • Understanding of series and parallel circuits
  • Basic electrical engineering principles
  • Experiment with Thevenin Equivalent Circuit calculations
  • Analyze power distribution in parallel versus series loads
  • Study the impact of load variations on circuit performance
  • Explore advanced circuit simulation tools like LTspice
Electrical engineering students, circuit designers, and professionals involved in power analysis and circuit simplification will benefit from this discussion.
_wolfgang_
In a thevenin equivalent circuit are you able to find the power used in the circuit by the variable load?
I have a circuit where the variable load is in parrallel I was thinking the power used in the original circuit by the variable load would be different than in the equivalent because it is in series.. Any ideas?
It's called the Thevinin Equivalent because its equivalent and it's purpose is to do exactly what you mention with it, that is convert a messy / complicated / busy circuit to a simple one so you can figure out some end result.
Why not try both ways and see for yourself!
  • · Replies 17 ·
  • · Replies 42 ·
