Quantizating a symmetric Dirac Lagrangian
The discussion revolves around the quantization of a symmetric Dirac Lagrangian, focusing on the implications of using independent fields for the Dirac spinor and the resulting canonical momenta. Participants explore the nature of anticommutation relations, the role of Grassman variables, and the foundational assumptions of quantum field theory.
  • One participant presents a symmetric form of the Dirac Lagrangian and questions the resulting anticommutation relations, noting a contradiction.
  • Another participant argues that the quantization procedure necessitates using only one type of field, suggesting no contradiction exists.
  • A participant expresses concern about an extra factor of 2 in their anticommutation relations compared to standard relations.
  • Another participant asserts that the fundamental Dirac parentheses do not require additional numerical factors and provides the canonical anticommutation rule.
  • A later reply points out a subtle mistake regarding the definition of canonical momentum, suggesting an additional minus sign was overlooked.
  • One participant questions the existence of anticommuting variables prior to defining canonical momentum.
  • Another participant states that the spinor field is inherently quantum, implying that it must obey the spin-statistics theorem and cannot be treated as a classical field.
  • A participant inquires about classical analogs of Poisson brackets that might anticommute.
  • Responses clarify that classical mechanics does not utilize anticommuting variables, but some argue that Grassman coordinates can have a classical analogy.
  • One participant asserts that classical spinors do not exist, as they arise from quantum theories through symmetry group representations.
Participants express differing views on the nature of spinors, the validity of classical analogs of anticommuting variables, and the implications of quantization procedures. There is no consensus on these points, and the discussion remains unresolved.
Some participants highlight limitations in the teaching of these concepts in standard courses, indicating a potential gap in understanding the foundational assumptions of quantum field theory and the treatment of spinors.
Rocky Raccoon
As is well known, a Dirac Lagrangian can be written in a symmetric form:
L = i/2 (\bar\psi \gamma \partial (\psi) - \partial (\bar\psi) \gamma \psi ) - m \bar\psi \psi
Let \psi and \psi^\dagger be independent fields. The corresponding canonical momenta are
p = i/2 \psi^\dagger;
p^\dagger = - i/2 \psi.
The anticommutation relations would be
{(\psi)_k, i/2 (\psi^dagger)_m}= i delta_km,
{(\psi^\dagger)_k, - i/2 (\psi)_m}= i delta_km,
which are in contradiction with one another. How can this happen?
Actually the quantization procedure forces you to use only one type of fields, either the coordinate fields, or their momenta. So one has only one set of anticommutation relations between the fields (operator-valued distributions).
No contradiction.
OK, I thought so. But, with this Lagrangian, I get an extra factor 2 in my anticommutation relations compared to the standard anticomm. relations.
Then you must have made an error somewhere. The fundamental Dirac parentheses are
[tex]\left[\Psi^{a}(x),\bar{\Psi}_b (y)\right]_{+, x^0 = y^0} ^{*} = - \delta^{a}_{b} \delta \left(\vec{x}-\vec{y}\right)[/tex]
and using the canonical anticommutation rule, one finds the needed anticommutation relations, no other numerical factor needed.
The mistake is quite subtle. You forgot to pick up an additional minus sign from passing [itex]\frac{\partial}{\partial\dot\psi}[/itex] through [itex]\bar\psi[/itex] when defining your canonical momentum [itex]p[/itex].
You should have gotten
[tex]p = -\frac{i}{2} \psi^\dagger.[/tex]
How can I have anticommuting variables before I define my canonical momentum which defines canonical commutation relations?
It turns out [itex]\psi[/itex] is a Grassman-valued function of spacetime -- even at the classical level. When you move to quantum mechanics, all this means is that its matrix elements will be Grassman-valued too.
This was never taught at my relativistic quantum mechanics class :( Even Greiner (a classic textbook) doesn't mention it. So, what is the basis for such an assumption?
Well, the so-called <classical level> of spinors or spinor fields doesn't exist. The Dirac field is already a quantum field. So it must obey the spin-statistics theorem, therefore it describes fermions. Quantizing a fermion field through commuting field operators doesn't produce a Hamiltonian bounded from below. This is the original argument of 1940(Wolfgang Pauli in the Physical Review).
Is there a classical analogy of Poisson brackets which anticommute?
Poisson brackets are part of the classical mechanics. Classical mechanics doesn't use anticommuting momenta and coordinates.
The assumption comes from quantum mechanics (yes, I know it's backwards, but that's the way it goes). You don't get a local quantum field theory with commuting spinors; you get it by using anticommuting spinors.
Classical level of spinors do exist. They are just Grassman-valued, which makes it pretty hard to observe.
Yes, there is; see below.
Not true. If [itex]\theta[/itex] is a Grassman coordinate and [itex]\pi[/itex] is its conjugate momentum. Then the Poisson bracket between two Grassman-valued dynamical quantities, [itex]A(\theta,\pi)[/itex] and [itex]B(\theta,\pi)[/itex] is defined to be
[tex] \{A,B\}=-\left(\frac{\partial A}{\partial \theta}\frac{\partial B}{\partial \pi}+\frac{\partial A}{\partial \pi}\frac{\partial B}{\partial \theta}\right),[/tex]
for the convention of left derivatives.
There's no such thing of classical spinors, they come from purely quantum theories via symmetry group representations as is the case for Weyl & Dirac spinors.
  • · Replies 24 ·
