| New Reply |
Bohmian Mechanics - One Quick Question |
Share Thread | Thread Tools |
| Jun6-11, 04:08 PM | #1 |
Can you consider the particles in Bohmian Mechanics mixtures?
| Jun6-11, 05:57 PM | #2 |
DeBB theory describes the likely state of matter as it actually is, whatever processes it may be part of. If you start talking e.g. about density matrices or mixtures this refers to our partial knowledge of a system which is in itself well-defined. You need to distinguish between the case where the components waves do not physically coexist (a 'proper mixture') and the case where they do physically coexist but do not overlap (an 'improper mixture'). |
| Jun6-11, 09:43 PM | #3 |
Can actual particle position (the one that comes out of the guiding equation) be observed/measured or even influence anything at all? If yes, how? If not, what's is good for?
| Jun7-11, 02:48 AM | #4 |
| Jun7-11, 04:46 AM | #5 |
If we knew the entire initial state we could predict the evolution at any arbitrary moment of time and the uncertainty principle would not have applied. But since we do not know the initial state, the numbers are out of our reach. And we cannot increase our knowledge through experiments because every time we do a measurement we gain some knowledge but at the same time we introduce more unknowns through the degrees of freedom of measuring apparatus. In fact we cannot learn enough of it to increase out predictive power beyond the capabilities provided by wavefunction alone (w/o guiding equation). Does this all make sense? Is this a fair summary? To be honest, I sort of see how it all works but I still don't see a point. All these definite trajectories sound like an attempt to describe magnetic field of a permanent magnet by postulating the existence of invisible metal shavings that line up along the field lines ![]() DK |
| Jun7-11, 05:12 AM | #6 |
So let us concentrate on it. The following may also change your mind: http://www.physicsforums.com/blog.php?b=3077 |
| Jun7-11, 08:05 AM | #7 |
I guess my complain is that we have a guiding equation that is supposed to produce nice clean definite trajectories at all times but it is impossible to use for the stated purpose because we never have sufficient input data. And even when we do have definite trajectories, the only way we can use them is to plug them back into the same equation where they immediately get tangled with unknown/random environment to become probability distributions. The equation certainly makes sense, it helps visualise the flow of probability, I guess it can be handy in monte-carlo simulations etc. But there is nothing in it that requires coordinates to have definite values at all times. They might as well be distributions. DK |
| Jun7-11, 08:23 AM | #8 |
| New Reply |
| Thread Tools | |
Similar Threads for: Bohmian Mechanics - One Quick Question
| bohmian mechanics | Quantum Physics | 4 | ||
| Bohmian Mechanics and Time | General Physics | 0 | ||
| Bohmian mechanics disproved | General Physics | 9 | ||
| Bohmian Mechanics | Quantum Physics | 13 | ||
| Is Bohmian mechanics true?.. | General Physics | 2 | ||
