Titrations and buffers help, test tommorow
  • Thread starter Thread starter Nelo
    Buffers Test
The discussion revolves around solving a problem related to buffer solutions, specifically how to calculate the amount of ammonium chloride (NH4Cl) needed to create a buffer with a specific pH using ammonia (NH3) as the base. The participants explore different methods and concepts related to buffer calculations, including the use of ICE tables and the Henderson-Hasselbalch equation.
  • Homework-related
  • One participant expresses confusion about how to solve the problem, stating they understand the reverse process but struggle with the current question.
  • The same participant sets up an ICE table but encounters difficulties in calculating the concentration of NH4+ needed for the buffer.
  • Another participant questions whether the Henderson-Hasselbalch equation has been covered in class, indicating that they have not learned about pKa values and only simple buffers.
  • A different participant suggests that using ICE tables for buffer calculations is inefficient and recommends the Henderson-Hasselbalch equation as a more effective method, providing a brief outline of how to convert Kb to pKa.
  • There is a note about the importance of using correct notation in chemical formulas to avoid ambiguity.
Participants do not appear to reach a consensus on the best method for solving the buffer problem. Some advocate for the use of the Henderson-Hasselbalch equation, while others express uncertainty about their understanding of the necessary concepts.
Participants mention limitations in their current knowledge, such as not having covered the Henderson-Hasselbalch equation or pKa values, which may affect their ability to solve the problem effectively.
Nelo
I don't understand how to do this problem, but i Understand how to do the reverse of it.
"You have 25mL of 0.10M nh3 solution. How many grams of nh4Cl do you need to add to make a buffer with a ph of 9?) answer is 0.18M of nh4+.
What I've done is set up the initial table.
nh3 + h20 ----> nh4+ oh-
I 0.10 0.10
C-x +x x
edit::(this table is posting wrong.. but you get the point... x is on nh4 and oh h2o is neglected)
E0.10-10^-9 (keeping values same basically)
Second thing i did was solve x by doign the antilog of the -ph.
giving me 1*10^-9. which i believe is correct.
kb for nh4 is 1.8*10^-5.
I set up this : 1.8*10^-5 = 0.10x/ 0.10
End up getting the same answer as the constant. Cant be right, what am i doing wrong when the ph of the buffer is given?
Chemistry news on Phys.org
I 0.10 0.10
C-x +x x
Have you covered the Henderson Hasselbach equation in class?
No, we have not. we don't use pKa values at all. We simply have covered simple buffers. However I don't understand how to solve this question.. and apparently normal buffer questions when mol/L are different
Using ICE tables for buffer calculations - while sometimes possible - is a waste of time. There is a much better tool for that - Henderson-Hasselbalch equation.
This question is quite easy to solve - convert Kb to pKa (pKa + pKb = 14, pKb = -log(Kb)), plug everything given into HH equation, and solve for the only unknown - [HN4+].
Please don't ignore capital letters in formulas, they are there to avoid ambiguity. co doesn't meant anything as CO and Co are completely different things.
35K
9K
