Finding Momentum Density in Dirac Field
The momentum density in the Dirac field can be derived using the expression G defined as \mathbf{G}=\frac{\hbar}{4i}[\psi^\dagger \nabla \psi + \psi^\dagger \mathbf{\alpha} (\mathbf{\alpha} \cdot \nabla)\psi]+hc. This expression can be simplified using commutation relations for the matrices \alpha_k, leading to \mathbf{G}=\frac{\hbar}{2i}[\psi^\dagger \nabla \psi -(\nabla \psi ^\dagger)\psi]+\frac{\hbar}{4}\nabla \times (\psi^\dagger \mathbf{\sigma} \psi). To find the momentum density, one should utilize the real Lagrangian density of the Dirac field alongside the momentum density expression provided by Noether's theorem.
  • Understanding of Dirac field theory
  • Familiarity with Noether's theorem
  • Knowledge of quantum mechanics and wave functions
  • Proficiency in using commutation relations for matrices
  • Study the derivation of momentum density in quantum field theory
  • Learn about Noether's theorem and its applications in field theory
  • Explore the properties of Dirac matrices and their commutation relations
  • Investigate the real Lagrangian density formulation for the Dirac field
Physicists, particularly those specializing in quantum field theory, researchers studying the Dirac equation, and students seeking to understand momentum density in quantum systems.
da_willem
How can I find the momentum density in the dirac field? Can someone show me, tell me how or give me a reference?
Preferably not in relativistically covariant notation; I found this expression for the momentum density G, and want to know where it comes from:
[tex]\mathbf{G}=\frac{\hbar}{4i}[\psi^\dagger \nabla \psi + \psi^\dagger \mathbf{\alpha} (\mathbf{\alpha} \cdot \nabla)\psi]+hc[/tex]
with hc the hermitian conjugate of the expression. This can be written using the commutation relations for the matrices [itex]\alpha_k[/itex]:
[tex]\mathbf{G}=\frac{\hbar}{2i}[\psi^\dagger \nabla \psi -(\nabla \psi ^\dagger)\psi]+\frac{\hbar}{4}\nabla \times (\psi^\dagger \mathbf{\sigma} \psi)[/tex]
Nobody has ever seen this before?
U use the real Lagrangian density of the DIrac field and the expression for the momentum density given by Noether's theorem.
  • · Replies 56 ·
  • · Replies 24 ·
