New Reply
First order linear PDE, need help understanding solution/method
Share Thread Thread Tools
Aug22-11, 07:20 AM   #1
Solve the initial boundary value problem:
u_t + cu_x = -ku
u is a function of x,t
u(x,0) = 0, x > 0
u(0,t) = g(t), t > 0
treat the domains x > ct and x < ct differently in this problem. the boundary condition affects the solution in the region x < ct, while the IC affects it in the region x > ct.
3. The attempt at a solution
The question previous question walks you through transforming the coordinates to get the general solution:
A = x - ct B = t
So by the chain rule:
u_x = (dA/dx)u_A + (dB/dx)u_B
u_t = (dA/dt)u_A + (dB/dt)u_B
dA/dx = 1 dB/dt = 0
dA/dt = 1 dB/dt = 1
Therefore
u_x = u_A
u_t = -cu_A + u_B
the new equation is now:
-cu_A + u_B + cu_A + ku
= u_B + ku
therefore
u_B = -ku
--> u = exp(-kB).f(A)
--> u(x,t) = exp(-kt).f(x-ct)
the justification given here is: "since the intergration constant is only constant in B, it may depend on A". I don't understand this step, what does that justification mean? I see that all they did was swap from B and A back to x-ct and t though I dont quite understand whats happening.
Anyway, now we have the general solution, so we can work on the main part of the question:
Since u(x,0) = 0 then f(x) = 0 for x > 0
Since u(0,t) = g(t) then exp(-kt).f(-ct) = g(t) for t > 0
Here is where I get confused...
=> f(z) = g(-z/c) exp(-(kz/c)) for z < 0
then the next step says
=> u(x,t) = 0 for x > ct
and u(x,t) = exp(-kt).exp(-(k/c)*(x-ct)).g(-(x-ct)/c) for x < ct
=> u(x,t) = exp(-kx/c).g(t-(x/c)) for x < ct
No idea what happens once they substitute z, and why they are doing the things they've done. Any help is appreciated. Sorry for the difficult notation and thank you in advance!!!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Aug22-11, 11:39 AM   #2
Recognitions:
Homework Helper Homework Help
With four first equation, it's just s trick. The change of variables is perfectly valid, because if you calculate the Jacobian you obtain a non-zero result, that means the co-ordinate system (A,B) is perfectly allowable. Or that I think you mean that if f(x,y)=A(x) + B(y) say, then [itex]\partial f/\partial x=A'(x)[/itex], remember these are partial differentials that you're dealing with, not full ones.
For the second part of your question, you need to understand that f is a function of a single variable only, for the second part that are introducing a new variable z=-ct, as [itex]t\geqslant 0[/itex], we can say that [itex]z\leqslant 0[/itex], so we have found f(B) in two regions, when [itex]B\leqslant 0[/itex] and when [itex]B\geqslant 0[/itex]. The variable in the equation is x-ct, so for x-ct>0, the solution is zero, i.e. for x>ct and for x-ct<0, the solution is as you mentioned it, .e. for x<ct.
New Reply
Thread Tools
Similar Threads for: First order linear PDE, need help understanding solution/method
Thread Forum Replies
Frobenius method solution for linear ODE Differential Equations 1
First order Linear PDE, Method of Characteristics Calculus & Beyond Homework 2
Need help understanding linear equations of higher order Differential Equations 5
Method of characteristics for a 1st order quasi-linear PDE. Differential Equations 0
2nd order DEQ: weird solution method Calculus & Beyond Homework 6
