| New Reply |
Entropy of running water around a resistor |
Share Thread |
| Aug27-11, 08:22 AM | #1 |
An electric current of 10A runs for 1 minute through a 20 ohm Resistor which is maintained at 10 degC by being immersed in running water. What are the entropy changes in a) the resistor b) the running water c) the universe 2. Relevant equations P = I2R dS = dQ/T 3. The attempt at a solution For a) there is no change in the entropy as it is work done by the resistor, not heat. b) I've calculated P = 2000W = 2000J The problem I'm having is formulating the path between the initial and final states of the system because of the constant temperature. I'm also not sure if I'm using the right equation? c) This will be the same as the answer for b) I think. |
| Aug27-11, 08:45 AM | #2 |
Figured it out!
Forgot to convert the temperature to kelvin and then got everything written down in a mess! |
| New Reply |
| Tags |
| entropy, resistor, running water |
Similar discussions for: Entropy of running water around a resistor
| Entropy, resistor in a temperature bath | Classical Physics | 4 | ||
| Light Dependent Resistor in water | Electrical Engineering | 4 | ||
| Running a Car on Hydrogen Made from Water | General Physics | 77 | ||
| What is the entropy change of ice to water and water to vapor? | Introductory Physics Homework | 3 | ||
| Heating Water Using Circuit Resistor | Introductory Physics Homework | 1 | ||
