| New Reply |
Combination Problem |
Share Thread | Thread Tools |
| Sep6-11, 12:44 PM | #1 |
Combination Problem
You are given 8 balls, each of a different color. How many distinguishable ways can you: (1) Divide them (equally or unequally) between 2 urns. (2) Divide them (equally or unequally) between 2 children (and each child cares about the colors he or she receives). 2. Relevant equations These are the enumeration formulas we are responsible to know: Sampling with replacement and order: [itex]n^r[/itex] Sampling without replacement, without order: nCr = [itex]\frac{n!}{r!(n-r)!}[/itex] Sampling without replacement, with order: nPr = [itex]\frac{n!}{(n-r)!}[/itex] 3. The attempt at a solution I initially thought that problem (1) would be without replacement and without order, so that the answer would be a combination with n=8 and r=2, and that problem (2) would be without replacement and with order, so a permutation with n=8 and r=2. However, that isn't correct. It seems like it might actually be a case where there is replacement. The fact that we are giving the balls to two people, or placing them in two urns, is screwing me up. How can I think about this problem and go about solving it? Is it solvable with just the equations I've listed above? Thanks. 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution |
| Sep6-11, 12:59 PM | #2 |
Think about the 8 balls being lined up in a row.
_ _ _ _ _ _ _ _ Put a 1 in each place if the ball goes in urn A and a 0 if it goes in urn B. How many binary numbers does that give? Then it matters whether the urns are distinguishable. |
| Sep6-11, 01:24 PM | #3 |
Okay, so if for each ball there would be 2 options for urns, meaning that for the case when the urns are indistinguishable the options available would be:
[itex]2^8 = 256[/itex]. This would be a case where order matters, right? When order doesn't matter I'd have to divide by the number or repetitions, but I'm not understanding how to do that... |
| Sep6-11, 01:42 PM | #4 |
Combination ProblemI'm afraid the wording of the problem is a bit ambiguous regarding the difference between 1 and 2. The balls are all different colors. If in 1 you are supposed to ignore the colors I would think the problem would state that. In any case we have answered 2, assuming the two children aren't identical twins. |
| New Reply |
| Thread Tools | |
Similar Threads for: Combination Problem
| combination problem help? | Calculus & Beyond Homework | 6 | ||
| Combination Problem | Precalculus Mathematics Homework | 3 | ||
| Combination problem | Precalculus Mathematics Homework | 2 | ||
| Combination Problem | Precalculus Mathematics Homework | 1 | ||
| combination problem | General Math | 8 | ||
