Are Network Firewalls Ruining Your Internet Experience?
  • Thread starter Thread starter BLUE_CHIP
    Network
Network firewalls, specifically the WebMartial system implemented by the school, are significantly degrading internet performance for users. The recent server reset by the new head of computing has reactivated WebMartial, which restricts access and closes ports, leading to slow load times and limited functionality. The user previously utilized an HTTP Tunnel for proxy access, which is now ineffective due to these restrictions. Immediate solutions are needed to identify open ports and restore efficient internet access.
  • Understanding of network firewalls and their impact on internet performance
  • Familiarity with HTTP Tunneling and proxy configurations
  • Knowledge of port scanning techniques and tools
  • Basic networking concepts, including workgroups and domain authentication
  • Research methods for identifying open ports on a network
  • Learn about alternative proxy solutions that may bypass restrictive firewalls
  • Explore the configuration and management of WebMartial for potential adjustments
  • Investigate the use of VPNs to circumvent network restrictions
This discussion is beneficial for network administrators, students experiencing restrictive school networks, and anyone seeking to optimize their internet experience under firewall constraints.
BLUE_CHIP
AAAAAAHHHH! :mad:
The aogony of network firewalls, It took me 5 mins to load up this page on a connection that is supposedly 1M. All because my school finds the need to check every single packet that is sent to and from my computer.
Up until a week ago everything was fine because I was authenticating myself on a workgroup as supposed to on the normal school domain. This meant that "WebMartial" was not active and i brilliant broadband access.
Then came the new head of computing. he saw it all, all of the corruption and filesharing and he thought hed to something about it.
He pressed the reset button on the Server. WebMartial reasserted itself defaultly over the entire network, Workgroup and Domain. Everything was Dashed.
Previously I had been using an HTTP Tunnel to create a Proxy which my MSN messenger could use. It was rerouting through port 4463, as soon as the server was reset all port were closed and so MSN was useless.
Now I am having to run my internet through WebMartial. Its Agonising. Its going to take 10 minutes just ot post this.
Im working on a solution but Trying to find which ports are open is proving difficult. Port scanning doesn't work, all i need is a way to be able to use the internet properly.
If anyone here can give me any ideas, it would be wonderful.
Yours BLUE_CHIP
Computer science news on Phys.org
Are you sure Port Scanning doesn't work? Which port scanning program are you using?
There's many things you could do. Most of which you'll probably get in trouble for.
Sorry, this isn't appropriate.
10K
  • Sticky
9K
