Solving Equilibrium of Glass Cylinder w/ Coil Wrapped Around It
The discussion focuses on determining the loop current I required for a glass cylinder with a 10-turn coil to achieve static equilibrium on a ramp inclined at angle θ in the presence of a uniform magnetic field B. The solution involves equating the gravitational force acting on the cylinder, expressed as Fg = gρl2∏R^2 * sin(θ), to the magnetic force on the current, ILBsin(θ). The correct expression for the loop current is derived as I = gρπR^2/(20B), accounting for the torque generated by the two sides of the coil affecting the magnetic force.
  • Understanding of static equilibrium in physics
  • Knowledge of magnetic forces on current-carrying conductors
  • Familiarity with the concepts of torque and its application in rotational dynamics
  • Basic principles of electromagnetism, particularly involving solenoids
  • Study the principles of torque in rotational dynamics
  • Learn about the behavior of solenoids in magnetic fields
  • Explore the relationship between current, magnetic fields, and forces on conductors
  • Investigate applications of static equilibrium in engineering problems
Students in physics or engineering courses, particularly those studying electromagnetism and mechanics, as well as educators looking for examples of static equilibrium problems involving magnetic fields.
RichardEpic
A glass cylinder of radius R, length l, and density \rho has a 10-turn coil of wire wrapped lengthwise, as seen in the figure . The cylinder is placed on a ramp tilted at angle \theta with the edge of the coil parallel to the ramp. A uniform magnetic field of strength B points upward.
For what loop current I will the cylinder rest on the ramp in static equilibrium? Assume that static friction is large enough to keep the cylinder from simply sliding down the ramp without rotating.
Express your answer in terms of the variables R, l, \rho, \theta, B, and appropriate constants.
Force of gravity = mgSin(θ)
ρ = m / volume
volume = l*2∏R^2
l = length of the cylinder
B of coil = μIN/l
l = length of the solenoid
Force on a current = ILxB = ILBsin(θ)
L = length of the wire
I attempted to solve this equation by solving for the mass from the density equation given above: m = ρl2∏R^2
so: Fg = gρl2∏R^2 * sin(θ)
then, I set this equal to the Force of magnetism on a current...
gρl2∏R^2 * sin(θ) = ILBsin(θ)
sin(θ)'s cancel...the l's also apparently cancel...giving me:
(gρl2∏R^2)/B = I
The homework website says that all I'm missing is an incorrect multiplier. How would I factor in torque for this problem? I believe that may be the solution, unless it has something to do with the glass cylinder and the coil wrapped around it, or perhaps there's something specific to a magnetic field acting on a solenoid...Help would be greatly appreciated! :smile:
Your answer should have been I = g*rho*pi*R^2/(20B). This is due to the 2 sides affected by the magnetic force with 10 coils each making B=20IlB. This is to help anyone reading this archive and unfortunately not OP.
  • · Replies 23 ·
