New Reply
Differential equation after using Euler-Lagrange equations
Share Thread
Nov29-11, 07:04 AM   #1
Particle is moving along the curve parametrized as below (x,y,z) in uniform gravitational field. Using Euler- Lagrange equations find the motion of the particle.
3. The attempt at a solution
[tex]\begin{array}{ll} x=a \cos \phi & \dot{x}= -\dot{\phi} a \sin \phi \\
y=a \sin \phi & \dot{y}=\dot{\phi} a \cos \phi \\
z=b \phi & \dot{z}= b \dot{\phi} \\
\end{array}
[/tex]
Lagrangean will be :
[tex] L=T-V=\frac{m}{2}\dot{\phi}^{2}(a^{2}+b^{2})-mgb\phi[/tex]
Using Euler-Lagrange equations we obtain:
[tex]\frac{d}{dt}\left(\frac{\partial \mathcal{L}}{\partial \dot{q_{l}}}\right)-\frac{\partial \mathcal{L}}{\partial q_{l}}=0[/tex]
[tex]m\ddot{\phi}(a^{2}+b^{2})+mgb=0[/tex]
How to deal with such differential equation ?
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Nov29-11, 08:20 AM   #2
Recognitions:
Homework Helper Homework Help
So [itex]\phi[/itex] is the only generalised co-ordinate, and all the other letters are constants, right?
In that case, this is a differential equation of the form [tex]\ddot\phi = c[/tex] which gives a simple linear solution (which makes sense, because the only freedom you have is how fast you move along the curve).
Nov29-11, 10:08 AM   #3
So all i need to do is double integration ?
Nov29-11, 04:29 PM   #4
Quote by Zaknife View Post
That's correct. Write the equation in the form suggested by CompuChip and then integrate twice with respect to time. Since the right side is a constant is pretty simple to do.
Nov29-11, 11:47 PM   #5
Recognitions:
The particle is moving along a helix (on a circular cylinder) with constant angular velocity. Therefore the angle in the plane xOy depends quadratically on time.
New Reply
Similar discussions for: Differential equation after using Euler-Lagrange equations
Thread Forum Replies
Euler-Lagrange equations Calculus & Beyond Homework 3
Euler-Lagrange Equations Advanced Physics Homework 3
Anyone know how to interpret the euler-lagrange differential equation? Calculus & Beyond Homework 1
Anyone know how to interprete the Euler-Lagrange differential equation? Calculus & Beyond Homework 0
Euler-LaGrange equations Advanced Physics Homework 6
