Vapor Pressure of a pure solvent
The vapor pressure of a pure solvent remains constant regardless of changes in its concentration, as long as no solute is added. The discussion clarifies that concentration changes in a pure solvent can only occur through physical means, such as temperature variations or volume adjustments, rather than solute addition. Therefore, the vapor pressure is solely dependent on the temperature and intrinsic properties of the solvent, not its concentration.
  • Understanding of vapor pressure concepts
  • Knowledge of physical properties of solvents
  • Familiarity with temperature effects on vapor pressure
  • Basic principles of thermodynamics
  • Research the relationship between temperature and vapor pressure of solvents
  • Explore Raoult's Law and its implications for vapor pressure
  • Investigate the effects of volume changes on vapor pressure
  • Learn about the phase transitions of pure solvents
Chemistry students, researchers in physical chemistry, and professionals studying solvent behavior in various applications.
thewall12
I know that the vapor pressure of a solvent would decrease with a changing concentration if there was an addition of a solute. However, would the vapor pressure change with a changing concentration of the pure solvent (no solute added)?
Chemistry news on Phys.org
How are you going to change concentration of the solvent without adding solute?
  • · Replies 115 ·
12K
