The discussion revolves around the meanings of Fh and Fv in monitor specifications, specifically in relation to the ViewSonic E771 monitor. Participants explore the implications of these specifications on refresh rates and the performance of different types of monitors, including CRT and LCD.
- Technical explanation
- Debate/contested
- One participant identifies Fh as horizontal frequency and Fv as vertical frequency.
- Another participant suggests that setting the refresh rate to 120Hz should be fine, provided the video card can support it.
- Some participants express that higher refresh rates are generally better, noting that the human eye can perceive flickering around 60Hz.
- There is a claim that LCD monitors typically do not refresh faster than 60Hz, with some suggesting that high-end models may reach 70-80Hz.
- One participant asserts that flicker is not an issue with LCD monitors since they do not use phosphors, contrasting this with CRT monitors.
Participants express differing views on the refresh rates achievable by LCD monitors, with some asserting that 120Hz is possible while others claim that they have not seen LCDs refresh faster than 60Hz. The discussion remains unresolved regarding the maximum refresh rates of various monitor types.
There are limitations in the discussion regarding the specific capabilities of different monitor technologies and the conditions under which refresh rates can be set. The claims about refresh rates depend on the definitions of monitor types and the capabilities of associated hardware.
