| New Reply |
I have cation concentrations. How to figure out corresponding H and O concentrations? |
Share Thread | Thread Tools |
| Jan18-12, 07:23 AM | #1 |
Hello all:
I would like to test some software, to find out whether it works correctly. To do this, I want to reproduce a calculation that someone did using a different method. This calculation involves chemistry, and my chemistry skills are not great. I would really appreciate if someone could help me out with what is probably a rookie question! I have data for cation/anion concentrations. But for some reason, although the cations are within a fluid made up of H and O, the H and O data are not given. Given the cation concentrations, is it possible to figure out the corresponding amounts of H and O? If so, how? millimoles/liter Na + = 110.0 Mg2+ = 5.0 Ca2+ = 0.966 Cl- = 121 Thanks a lot for any help! |
| Jan18-12, 09:28 AM | #2 |
Admin
For very precise calculations you would need solution density. For approximate calculations, you can safely assume concentration of water to be 1000/18 mol/L.
But I have a feeling you might be trying to do something unnecessary, something that has a source in your confusion. |
| Jan18-12, 11:01 AM | #3 |
Thanks a lot Borek. You are probably right that I don't properly understand this...
What is the significance of the 1000/18? I just need the concentration of H and O that would go along with the cation concentrations (if that is possible). I can then find out the solution density. If it helps, this is all at 25 C. |
| Jan18-12, 12:53 PM | #4 |
Admin
You can't find solution density after - this is a thing that has to be measured, so you need to know it before being able to calculate anything. Solution is rather diluted, so it will be quite close to 1.00 g/mL - could be that's accurate enough for your needs.
1000/18 is just a molar concentration of pure water - assuming 1.00g/mL, 1L mass is 1000g, molar mass of water is 18g/mol. Knowing molar concentration of water you can calculate amount of H and O (although it doesn't make much sense to me - it could make sense as a part of the proper mass balance for the system, but I doubt you need it). |
| Jan18-12, 01:18 PM | #5 |
Thanks Borek, this helps a lot.
I got the data from a paper published by people who tested their code. I don't understand why they don't specify H and O if it isn't clear what H and O must be! Anyway, maybe they used the assumption you describe, so I'll try that. Much appreciated. |
| Jan18-12, 02:47 PM | #6 |
Admin
Concentration of water is usually considered to be constant, so - depending on what you do - you can completely ignore its presence. Perhaps that's the case.
| New Reply |
| Tags |
| concentration, concentrations, solutions, water |
| Thread Tools | |
Similar Threads for: I have cation concentrations. How to figure out corresponding H and O concentrations?
| PPM concentrations | Chemistry | 1 | ||
| dilutions and concentrations | Chemistry | 1 | ||
| Simplified.... 2.0 mL .20M "X" added to 9ml | Biology, Chemistry & Other Homework | 7 | ||
| Adding Concentrations | Biology, Chemistry & Other Homework | 2 | ||
| concentration with my physics major | Academic Guidance | 2 | ||
