Geometric Sequences and Logarithms
The discussion revolves around geometric sequences and logarithms, specifically focusing on a sequence with a negative common ratio. The original poster is attempting to find the number of terms and the sum of the sequence given the first term, common ratio, and last term.
  • Mixed
  • The original poster attempts to solve for the number of terms using logarithms but encounters issues due to the negative common ratio. Some participants suggest ignoring the negative sign for simplification, while others emphasize the importance of considering it.
Participants are exploring different interpretations of how to handle the negative common ratio in the context of logarithms. Some guidance has been offered regarding the use of absolute values and the implications of taking logarithms of negative numbers, but no consensus has been reached on the best approach.
There is a discussion about the constraints of logarithmic functions, particularly regarding negative values, and the implications for the calculations being performed. The original poster is also navigating the complexities of the problem without using sigma notation.
Astronomer107
I'm having trouble with these type of probles (where a negative log comes up):
(All of this is solving without sigma notation)
Find the number of terms in these geometric sequences and the sum of the numbers.
11, -22, 44,...,704
I know that a1 = 11, r = -2, and an = 704, so I did:
704 = 11(-2)^n-1 so,
64 = (-2)^n-1
log 64 = (log -2) n-1
n should = 7, but when I found the log of 64 divided by the log of -2, I got .2785219413 - 1.2...
Why is there a minus sign and what am I doing wrong? Please help. Thanks!
Ignore the fact that the ratio is negative, since it will cause problems with the logarithm. (You can't take the log of a negative number)
the equation should start out as
704 = 11*2^x
so basically you get
11 * 2 * 2 * 2 * ... = 704
you can simpliffy the equation by dividing both sides of the equation by 11
2^x = 64
x = ln(64)/ln(2) = 6
Then you have to add 1 to account for the first term
therefore the number of terms is 7
You don't just ignore the negative sign; you take the absolute value of both sides.
(and because it's a nonreversible operation, you mave to check your answer to make sure it works)
And, incidentally, you can take the logarithm of a negative number, but it does require you to take a step up to complex analysis... the logarithm of a negative number is a (nonunique) complex number, and it takes a lot of care to make sure you are doing everything right.
When you computed log 64 / log -2, the result is thus a complex number and your calculator reported the principal value of this expression. If you had scrolled your display to the right, you would have seen 'i' in the answer
THANK YOU!
  • · Replies 31 ·
