Are all open sets compact in the discrete topology?
  • Context: Graduate
  • Thread starter Thread starter Useful nucleus
    Compact Definition Sets
The discussion centers on the question of whether all open sets are compact in the discrete topology. Participants explore the definitions of compactness and open covers, providing examples and counterexamples to illustrate their points.
  • Some participants argue that since every open set can be expressed as a union of itself and the empty set, it implies that every open set is compact.
  • Others clarify that compactness requires every open cover to have a finite subcover, not just a specific example.
  • A participant provides an example using the open interval (0,1) to illustrate that certain open covers do not allow for a finite subcover.
  • There is a suggestion that the definition of an open cover should emphasize that the set must be a proper subset of the cover.
  • Another participant points out that while {F} is an open cover of F, compactness requires this to hold for all possible open covers.
  • One participant mentions the example of the integers in the discrete topology, where each singleton is open, and notes that covering the integers with singletons does not allow for a finite subcover.
  • Concerns are raised about the intuitiveness of the concept of compactness compared to other topological properties like connectedness.
Participants express differing views on the implications of the definitions of compactness and open covers. There is no consensus reached regarding whether all open sets are compact in the discrete topology, as multiple perspectives are presented.
Participants highlight the importance of understanding the definitions and conditions surrounding compactness and open covers, indicating that misconceptions may arise from not fully grasping these concepts.
Useful nucleus
A subset K of a metric space X is said to be compact if every open cover of K contains a finite subcover.
Does not this imply that every open set is compact. Because let F is open, then
F= F [itex]\bigcup[/itex] ∅. Since F and ∅ are open , we obtained a finite subcover of F.
Am I missing something here?
Every cover must have a finite subcover not just one or some of them.
But F[itex]\bigcup[/itex]∅ is contained in every open cover for F?
But F[itex]\bigcup[/itex]∅ is contained in every open cover?
As a subset, yes. But F and ∅ might not be elements of the open cover.
Compactness says that if you have an open cover -- a collection of open sets whose union covers F -- then some finite subcollection will also cover F. In other words you have to be able to pick out a finite collection of sets from your open cover, and show that the finite collection is also an open cover.
As an example, take F = (0,1), the open unit interval. Let A_n = (1/n, 1). Then the collection {A_n} for n = 1, 2, 3, ... is an open cover of F; but no finite subcollection of the A_n's covers (0,1). Working through this example will be helpful.
Then, I think the definition of the open cover of a set F has to emphasize that F has to be a proper subset of the cover. Otherwise the argument in my first post will be correct.
As SteveL7 said, F and ∅ may not be elements of the open cover. An open cover is a collection of open sets. F may not be in the collection.
Well if F is an open set, then {F} is indeed an open cover of F consisting of one set. So that's an example of one open cover of F that happens to have a finite subcover.
But compactness requires that EVERY open cover has a finite subcover.
I think you would find it helpful to work through the example of F = (0,1) that I gave earlier.
FWIW pretty much everyone has trouble learning about compactness. It's very unintuitive. Not like connectedness, say, whose technical definition matches our intuition about what a connected set should be. With compactness, it's like, "How did they ever think of that?"
SteveL27 and lavinia thank you very much for your help! I have a better understanding now of the definition. The open unit interval example was particularly helpful.
the usual example "in the other direction" (unbounded sets, rather than open sets) is R:
certainly {R} is an open cover of R. yet it hardly seems "right" to call R "compact", given how large it is.
and, of course, it is not:
{(n,n+2): n in Z} is an open cover of R, but we need "all |Z| of them" (and |Z| is not finite) to cover R, no finite subcover will do.
Here is a stark example.
Take the integers with the discrete topology. Here each singleton,{n}, is an open set.
Cover the integers with the set of singletons. Not onl;y is there no finite subcover, there is no subcover.
