Frustrating excel problem with COS
  • Thread starter Thread starter tommy060289
    Cos Excel
The discussion revolves around a problem encountered by a user while using Excel to calculate the cosine of an angle, specifically regarding the interpretation of input values in radians versus degrees. The scope includes technical explanations and proposed solutions for handling trigonometric calculations in Excel.
  • One participant, Tom, reports a discrepancy between the cosine value calculated by a calculator and Excel, suggesting that Excel interprets the input in radians rather than degrees.
  • Another participant suggests appending *(Pi()/180) to convert degrees to radians for the calculation.
  • A different participant proposes using the RADIANS() function to convert degrees to radians directly in the cosine function: COS(RADIANS(angle_in_degrees)).
  • It is noted that the input value of 9.863 is assumed to be in radians by Excel, which is clarified by another participant.
  • There is mention of a DEGREES() function for converting radians back to degrees when needed.
Participants generally agree on the interpretation of the input value in radians and propose various methods to address the issue, but there is no consensus on a single preferred solution.
Participants discuss the limitations of Excel's handling of angle measurements and the implications for users with numerous calculations, but specific assumptions or dependencies on definitions are not fully explored.
tommy060289
Dear all,
I am currently using excel to work out some values for incident solar radiation but I am running into a rather frustrating problem when I try to do the following:
=COS(9.863)
my calculator tells me correctly this is 0.985.
however, when I put this in excel it decides it actually equals 0.905, which is obviously wrong.
I've gathered this is an issue with excel giving the answer in Rads rather than degrees but I can not figure out how you force excel to output the correct answer (in degrees) and since I have thousands of calculations it isn't feasible for me to alter every one manually.
Cheers,
Tom
Computer science news on Phys.org
No worries, figured I can get it to change by adding:
*(Pi()/180) on the end
You can also use the RADIANS() function: COS(RADIANS(angle_in_degrees)).
And if you ever need to go the other way, there's a DEGREES() function: DEGREES(ACOS(x)).
Just to clarify, hopefully you realize the output result of =cos(9.863) is not in radians, it is the input number 9.863 that Excel assumes is in radians.
I didn't know that, thanks for the tip!
29K
