Rates of Reaction: Questions Answered
  • Thread starter Thread starter ChemRookie
    Reaction
The discussion revolves around questions related to rates of chemical reactions, including factors affecting reaction rates, the impact of temperature on reaction kinetics, and specific calculations related to activation energy and heat of reaction. The scope includes conceptual understanding, mathematical reasoning, and application of chemical principles.
  • Homework-related
  • Some participants suggest that reaction rates are highest at the beginning due to maximum concentrations of reactants present.
  • Others propose that factors such as surface area, temperature, and stirring can increase the rate of dissolving a lump of sugar.
  • One participant questions whether the electron configuration of reactants influences the speed of reactions, and whether there are general rules governing reaction rates.
  • Another participant notes that the equilibrium constant changes with temperature, affecting the rates of forward and reverse reactions, and suggests looking up relationships between rate constants and equilibrium constants.
  • There are inquiries about determining the heat of reaction and activation energy for a specific reaction, with some participants expressing uncertainty about the necessary data.
  • Some participants mention the Arrhenius Equation and Hess' Law as relevant concepts for the calculations discussed.
  • One participant emphasizes that the concentration of reactants decreases over time, which correlates with the rate of reaction.
Participants express a range of views on the factors affecting reaction rates and the implications of temperature changes. There is no consensus on the specific answers to the posed questions, and some participants seek clarification or additional information.
Some participants indicate that they lack sufficient data to answer specific questions regarding activation energy and heat of reaction, highlighting potential limitations in the information provided.
This discussion may be useful for students studying chemical kinetics, educators seeking examples of student inquiries, and individuals interested in the factors influencing reaction rates and related calculations.
ChemRookie
I have some quick questions that I need some help with:
1.
Why would a simple chemical reaction such as
NO9g) + 1/2O2(g) -----------> NO2(g) most likley be most rapid at the start?
2.
In what ways can the rate of dissolving a lump of sugar be increased? (at least 3)
3.
Finally, what effect would there be on the rate of constant of, forward reaction, and reverse reaction if there was an increase in temperature?
ChemRookie, you are asking us to do your homwork for you. We can't do that.
But we can help if you show what you have tried so far.
At least 2 of the 3 questions are pretty straightforward, and the answers should be in your text. You should be able to answer them without understanding a thing about kinetics. To answer the first question, you must first understand the concept of a reaction rate, and why it is the way it is. Once you get this, #1 is pretty obvious.
1) Think about what particles are present at the start - ie the concentration of the reactants are maximum at the start.
2) Look up how surface area : volume ratio affects reaction rate
3) Look up kinetic theory/Boltzmann distribution.
So...
1) Would the answer be that the chemicals involved in this reaction have a electron configuration in which they easily give off their electrons..therefore, easily react. ? Would it be specific to what chemicals they are, or is there just a rule that reactions are faster at the beginning?
2) obviously one is temperature, possibly also stirring faster? and maybe using a catalyst? (another substance to help it along)
3) for number 3. I know that a forward reaction is a reaction where the concentration increases with time, and a reverse is the other way around. So, how would an increase in temp affect the rate of constant of those 2..well, for a forward reaction, the the concentration would not increase I guess..since the reaction would happen quicker? for a reverse reaction, I guess it would have no affect?
#3. The equilibrium constant changes as the temperature varies since the ratio Rate forward/Rate reverse changes, find in your text a relationship/derivation of the equilibrium constant from the rate costants. Also note that an increase in temperature would now facilitate both reactions, since the energy of the system is now closer to the activation energies of both reactions...it is most often the case that the one reaction limited by kinetics will have its rate increased more in a relative sense.
one more question, here:
For the reaction
CO + NO2 ----> CO2 + NO the activation energy for the forward reaction is 135kj/mol of CO reacted.
a) determine the heat of reaction
b) from the data given, and the deltaHr for the reaction, determine the activation energy for the reverse reaction.
c) draw and label a potential energy diagram for the reaction
can someone help me with a and b at least..thanks. someone told me I don't have enough data to do the question and looks that way to me too.
can anyone answer if I have the neccesary info here? or any help with it
thanks.
a) Arrehenius Equation
b) Hess' Law
And I would do (c) before doing (b).
but, I don't have all of these variables.
http://www.shodor.org/UNChem/advanced/kin/arrhenius.html#a
the question:
For the reaction
and once I get the answer, how would I get the reverse reaction?
anybody?
T= 0degcel=293K?
P= 8.314J/mol K
E(a) = 135kj/mol
A= ?
what's the arrhenius constant?
k = -Ea/RT + ln A
ChemRookie said:
anybody?
T= 0degcel=293K?
P= 8.314J/mol K
E(a) = 135kj/mol
A= ?
k = -Ea/RT + ln A
The T should equals to 273k
Question 1. According to reaction rate and experimentally approved stated that rate is direct proportion to the concentration.At the initial time there are the highest concentration as long as the reaction took places the concentration gradually decrease simultaneously with rate of reaction.
