Partial Fractions: Simplifying Unfactorable Denominators
The discussion revolves around simplifying expressions involving partial fractions, specifically focusing on the equation \(\frac{1}{x^2+x+1} = \frac{1-x}{1-x^3}\). Participants are exploring methods to handle cases where the denominator is unfactorable.
  • Participants discuss the factorization of \(1-x^3\) and the potential use of long division to find factors. There is also a query about the method to transition from the left-hand side to the right-hand side of the equation without losing equivalence.
The conversation is ongoing, with participants offering insights into factorization techniques and questioning the assumptions behind the simplification process. Some guidance has been provided regarding the use of multiplication to maintain equivalence while altering the numerator.
There is mention of a solution manual that skips steps, leading to uncertainty about replicating the process in similar problems. The context includes a reference to Maclaurin's series, indicating a specific application for the simplification.
hqjb
In one of the workings of a question I couldn't solve(from solution sheet) there was one step I couldn't understand.
[itex]\frac{1}{x^2+x+1} = \frac{1-x}{1-x^3}[/itex]
Tried partial fractions(unfactorable denominator) and could'nt get it, finally got it through trial and error but is there a method where you apply to all such expressions to simplify it?
You're wanting to factorize (1-x³). You can see that x=1 solves it, so take out (x-1) as a factor.
How to do this? Do you know the "long division" method for dividing (1-x³) by (x-1)? This will give you the other factor.
:: EDIT:: I assumed you were working from the RH expression, wanting to find the LHE. Maybe you weren't. Which do you regard as the "simplest" expression here? :smile:
Haha sorry if I didnt put it into context properly. I wanted to obtain the RHE from the LHE, it wasnt a proving question but rather the solution manual skipped steps from LH-> RH and I'm not sure how he did it and if I can replicate it on a similar question without hindsight.
Edit : It's for Mclaurin's series for I needed it in 1\(1-x) form.
If you want to go from the LHS to the RHS of [tex]\frac{1}{x^2+x+1}\equiv \frac{1-x}{1-x^3}[/tex] then what you need is for the numerators to be equivalent, but at the same time you can't change the LHS expression.
So what you can do is use [tex]\frac{1}{x^2+x+1}\cdot \frac{1-x}{1-x}[/tex] to get the numerator the way you want it, and simultaneously keeping the expression equal.
Alright thanks!
