Magnetic moment of a current loop.
The magnetic moment of a current loop can be calculated using the formula \vec m = \frac{1}2 \int \vec r \times \vec J(\vec r) d^3\vec r. When the current is confined to a single planar wire, the current density is expressed as \vec J(\vec r) = I δ(z) δ(\vec r-\vec r' ), leading to the simplification of the magnetic moment to \vec m = I \vec A, where \vec A is the area vector of the loop. The derivation involves trigonometric relationships and geometric interpretations of the area swept by the current, confirming the relationship between the magnetic moment and the area vector.
  • Understanding of vector calculus and integrals
  • Familiarity with magnetic moment concepts
  • Knowledge of current density and its representation
  • Basic trigonometry and geometry
  • Study the derivation of magnetic moments in different geometries
  • Explore applications of the magnetic moment in electromagnetism
  • Learn about the Biot-Savart Law and its relation to magnetic fields
  • Investigate the implications of magnetic moments in quantum mechanics
Physicists, electrical engineers, and students studying electromagnetism or magnetostatics will benefit from this discussion, particularly those interested in the mathematical foundations of magnetic moments and their applications.
center o bass
Hello, calculating the magnetic moment of a current loop is trivial, but I want to do it with the general formula
[tex]\vec m = \frac{1}2 \int \vec r \times \vec J(\vec r) d^3\vec r[/tex]
The only thing which is stopping me is to find a good argument on why
[tex]\frac{1}{2}\int \vec r d\vec r = \vec A[/tex] where [tex]\vec A[/tex] is the area vector of the loop. Is there a formal way of proving this or any intuitive diagrams one can draw to show that it must be true.
Start with:
If the current is confined to a single planar wire:
[tex]\vec J(\vec r) = I δ(z) δ(\vec r-\vec r' )[/tex]
which leads to:
[tex]\vec m = \frac{I}2 \int \vec r' \times \vec d r'[/tex]
[tex]\vec m = \hat{z}\frac{I}2 \int r' sin γ d r'[/tex]
Now a little bit of trigonometry reveals that sin γ d r' is just the incremental arc length ds of the arc perpendicular to the radial vector:
[tex]\vec m = \hat{z} I \int \frac{1}2 r' ds[/tex]
The incremental wedge swept out by each incremental arc is essentially just a triangle with area of one half the base length times height. Here r' is the length of the triangular wedge, and ds is the height of the wedge, so the integrand is just the area of the wedge:
[tex]\vec m =\hat{z} I \int d a[/tex]
[tex]\vec m = I \vec A[/tex]
  • · Replies 32 ·
