Why is my Camera USB not automatically importing photos on Windows 7?
  • Thread starter Thread starter biferi
    Camera Usb
The discussion revolves around troubleshooting issues with a Canon SD1000 camera not automatically importing photos on a Windows 7 system. Participants explore various potential causes and solutions, including driver issues, registry problems, and settings adjustments.
  • One participant describes their initial setup where the camera automatically imported photos, but this functionality has stopped working.
  • Another suggests searching for downloadable driver software from the manufacturer, despite the camera not requiring a driver according to Canon.
  • Some participants propose that registry issues might be causing the problem, with one recommending a system restore to a point before the issue began.
  • There are suggestions to uninstall the default driver and use a registry cleaner to fix potential registry errors.
  • One participant expresses concern about losing files on their desktop during system restore operations.
  • Another asks for clarification on how to disable the camera in Device Manager and how to manually search for drivers.
  • Participants discuss the need for default programs in Windows 7 to handle autoplay functions, with some uncertainty about whether such programs can be uninstalled.
  • One participant mentions setting VLC as the default program for media but questions if this affects the camera's functionality.
  • Instructions are provided for adjusting AutoPlay settings to ensure the camera is recognized for importing pictures.
  • There is a mention of registry edits to enable AutoRun features, with one participant encountering difficulties navigating the registry structure.
Participants do not reach a consensus on the cause of the issue or the effectiveness of the proposed solutions. Multiple competing views on how to resolve the problem remain, with some suggestions being more technical than others.
Some participants express uncertainty about the implications of registry changes and system restore processes, indicating potential limitations in their understanding of these technical aspects.
Users experiencing similar issues with camera connectivity and photo import functionality on Windows 7, particularly those with technical backgrounds or interest in troubleshooting hardware and software interactions.
biferi
I have win7. premiume 64 Bit and a Canan SD1,000 camara.
The first time I pluged my Camara in win7. gave me a window on the system tray asking me how I want to import the photos.
So I set it up to Automaticly import all photos to a Folder on the Desktop.
So now whenever I plug the Camara in it automaticly imported all photos to a Folder on my Desktop.
It worked for a long time now when I plug my Camara in nothing happens I have to go into Computer then Right click the Camara icone the click Import photos and then it works.
It does not do it automaticly like I set it up to so I Plug the Camara in and bring up the Auto Play windows and at the bottom of the window were is says Removable Devices nothing is there. I thought if my Camara was there I could reset everything.
But I did see a Tab that says Reset everything to Default so I click it and then restart the system.
And when I plug the Camara in nothing comes up asking me how I want to import photos.
Please help the Camara had no Drivers it never ghad any?
And when I plug the Camara in and anyother USB device I do hear the Ding Ding sound it is two Dings and they are the same sound?
Computer science news on Phys.org
search the internet for driver software for the camera. Just because Windows has a default driver doesn't mean the manufacturer didn't also create a downloadable driver.
The Camara did not come with a Driver and Canan tells me it does not need one?
you've probably got a registry problem and I have no idea how you might fix it.
most of these settings are in the registry like phinds said. I would suggest you do a system restore to date BEFORE the problem started.
Start>All programs>Accessories>System Tools>System Restore
see if that fixes the problem for you.
P.S. System restore only deals with system settings not data. So stuff like you documents, music, pictures will be safe.
Go Control Panel->Device Manager
In Device Manager if you find Canon Sd1000 camera , click on its properties.
Try un-installing the default driver and disabling the device.
Disconnect the camera.
Download CC Cleaner or any other similar registry cleaner application ,(most of them are freewares , including CC Cleaner ).
Clean the registry , temporary files and all the unnecessary stuffs.
Reboot the system.
Plug in the Camera and it will automatically re-install the driver for your camera.
In case it doesn't , then goto device manaager and enable the device and search for driver in" C:\ "
After its successfully installed , follow the steps you normally do to import the pictures automatically from it to desktop.
Lt us know if this works for you.
Rishi.
Whenever I do a system Restore any Files on my Desktop go away and thing I was working on change. And it sould not but it always does?
Thank you for the help but how do you Disable the Camara in Device Manager after I un install the Driver??
And how do I look for the Driver in C:\ I only know how to just have Device Manager install Drivers by itself by clicking on Install Driver Tab?
I plug CAM. in and in device manager I Disable it and un install it.
Then I ran CCleaner and got rid off all tem and old files and had it fix Registray errors.
Save and reboot and then plug CAM. back in it loaded drivers and I did an Update that it told me the Best driver was installed.
It does the same thing I have to go to Cam icone and right click it and click import photos.
I can not get windows to ask me where do I want to import the photos anymore.
And I go into Autoplay screen and for Picture and Photos I have import Ask Me Every Tims.
What now
PS thank you for all the help
I do not have PIcasa installed or anything lioke this for photos.
But does win7. need a progrtam like this becaue I did un install a lot of win7. programs I did not need?
Does win7. have a default program that it needs to open Autoplay window when a CAM. is connected?
No , its not necessary.
Default programms can not be uninstalled or removed as such , so don't worry.
I am not sure but I think windows photo viewer is the defualt tool for picture viewing in windows 7.
Btw , have you tried the links I mentioned in my previous post. ? Those links describe the procedure for auto import of pictures from any external imaging device. Please try reading them thoroughly.
Rishi.
I did go into the setting to have a program set for diferant things. And I set VLC for everything but this sould just be for Music Videos and so on do I have to check in here and I am not sure were I was to do this?
And I do have my win7. set to Clasic Look does this tell you anything?
Try This,
Goto Control Panel-> AutoPlay
In AutoPlay mark the following option ,
"Choose what happens when you insert each type of media or device."
-Click on the CheckBox that says : "Use autoplay for all media and devices."
Scroll down to bottom and select your device.
Select "Import pictures and videos using Windows", from dropdown list.
click on save.
I have provided some screenshots for your ease that I took today.
check the attached files.
My Autoplay window does not open like this my window says
Use Autoplay For All Devices. And I put a check mark in the Box to Enable it.
Then down the page on the left side has a list of all the things you will need Autoplay for.
CD
DVD
Pictures
Enhanhanced Audio CD
And so on.
So next to Pictures is the Dropdown Box and I pick Import Pictures useing Windows.
Then all the way at the Bottom of the page on the right is SAVE Tab and I click this.
These things are the only things on the page.
And it does not help I did it and I whent to the links you posted to no go.
I called Canan and they told me I do not have to re set the PTP Mode and I can not. And it happens with Vista and win7. in the Registry but they are no help. They can not help me
I did go into Regedit and whent to
HKEY LOCALE MACHINE/SOFTWARE/MICROSOFT/WINDOWS/CURRENT VERSON/POLICES/EXPLORE
Then I right click on Explorer in the Tree and click Dword32 Bit.
Then it puts the new item on the right side window so I go to that and give it the name NoDriveTypeAutoRun
And then I give the Value of HEX 0x00000091
Now I go to do the same thing for
HKEY CURRENT USER/SOFTWARE/MICROSOFT/WINDOWS/CURRENT VERSON/POLICES/EXPLORER
But when I click the + nexto Current Verson the Polices folder and Explorer folder both drop down under it.
There is no + next to Polices folder and explorer folder is right there under the Polices folder not in the Polices folder.?
  • · Replies 123 ·
21K
