| New Reply |
How to apply force on fence in Ansys Workbench 14 |
Share Thread | Thread Tools |
| Jun26-12, 04:56 AM | #1 |
I have a box, the bottom and the four walls are made of grid. I wan to apply load in the box and see how the bottom and the four walls deform (and stress too). How can I do it? I do not want to apply a force to each wire vertically and horizontally. I want to apply a load to the bottom and the walls lika applying pressure to a surface. Thanks in advance.
| Jun26-12, 09:08 PM | #2 |
Recognitions:
gu93togi: Let the pressure you want to apply be p. Compute force F = p*A, where A = area of each grid. Select all wire intersection nodes on one box side, and apply force F to each node. Repeat for each box side and the bottom. See if this might work for you.
| Jun27-12, 07:43 AM | #3 |
I can not select all wires at the same time and apply force to them. I have to select the wire one by one. It is a way to select all wires at once and apply same force to all of them? Thank you in advance.
| New Reply |
| Thread Tools | |
Similar Threads for: How to apply force on fence in Ansys Workbench 14
| CMS analysis in ANSYS Workbench 14.0 | Mechanical Engineering | 0 | ||
| ANSYS Workbench scripting | Mechanical Engineering | 0 | ||
| Ansys Workbench Scripting... | Mechanical Engineering | 0 | ||
| ansys workbench | General Engineering | 0 | ||
| ANSYS workbench 11 mesh help! | Mechanical Engineering | 25 | ||
