The Equation for Volumetric Flow Rate?
by skoopfadj
Tags: equation, flow, rate, volumetric
skoopfadj
skoopfadj is offline
#1
Nov27-12, 03:44 AM
P: 8
I'm not sure how to clearly express my query, so I'll round up the gist of it. I understand that this is an entry level question.
I was told that, in order to calculate Volume Flow Rate (VFR), I would use these equations:
* Q = Velocity * Area [EQUATION 1]
* Q = Volume / Time [EQUATION 2]
Units: m^3 / s
Questions:
^Do I use both equations? Are they both deemed correct or only one and which one?
^Can you give an example problem or scenario in which I would use the appropriate equation?
Phys.Org News Partner Physics news on Phys.org
Sensitive detection method may help impede illicit nuclear trafficking
CERN: World-record current in a superconductor
Beam on target: CEBAF accelerator achieves 12 GeV commissioning milestone
WillemBouwer
WillemBouwer is offline
#2
Nov27-12, 04:55 AM
P: 82
Example: You have a pipe with a diameter of 400mm. Water flows through the pipe at a velocity of 1 m/s. Determine how many liters you would have collected in a minute?
Use your equation as you mentioned and come up with a solution, don't et sidetracked by the units, do the first principals correctly...
skoopfadj
#3
Nov27-12, 05:33 AM
P: 8
@WillemBouwer Correct?
Prompt: A pipe has a diameter of .4 meters. Water flows through the pipe at 1 m/s. Determine how many liters (water) you would have collected in a minute?
Radius: .2 meters (m)
Vinitial: 1 m/s
Volume: ?
Time: 60 seconds
Q = V * A
Q = 1 * (∏(.22))
Q = 0 .1256637061 m3/s
--> Q = V / T
.1256637061 = V / 60
Volume = 7.539822369 m3 or
7.539822369 * 1000 = 7,539.822369 L
1 m3 = 1000 Liters (L)
WillemBouwer
#4
Nov27-12, 05:41 AM
P: 82
There you go... Using the equation right...
The second equation is just an explaining of the units or terminology, Volume flowrate is exactly that, m^3/s, volume over time. But the first equation is the most commonly used.
However when you get a question, make sure to answer the question as asked with units, always remember your units... But you understand the principal! Cool beans...
So, how many liters per minute?
skoopfadj
#5
Nov27-12, 05:50 AM
P: 8
It should be on there.
7,539.822369 L ?
Thank you very much Mr. Bouwer. (:
WillemBouwer
#6
Nov27-12, 06:00 AM
P: 82
No problem. I see it shows now, didn't the previous one, haha. good job though, correct answer...
Register to reply
Related Discussions
Volumetric flow rate - Help needed Mechanical Engineering 0
At what volumetric flow rate will air fill a space vacuum at Earth's STP? General Physics 19
Volumetric flow rate (simple???) Engineering, Comp Sci, & Technology Homework 1
volumetric flow rate Engineering Systems & Design 7
