Finding net force using velocity graph?
The discussion revolves around determining the net force acting on an object using its velocity graph. The object in question has a mass of 2.5 kg, and participants are trying to analyze the graph to find the force at a specific time, t=7 seconds.
  • Participants discuss methods to find acceleration from the velocity graph, with some attempting to calculate force using the formula F=ma. There are questions about the accuracy of the calculated acceleration values and the implications of the graph's slope.
Several participants have shared their calculations and results, with some expressing uncertainty about their findings. There is a mix of attempts to clarify the relationship between acceleration and force, and some have provided alternative suggestions for analyzing the graph.
There is mention of the need to plot acceleration on the same graph and to consider the linearity of velocity changes. Participants are also reflecting on the implications of their calculations and the conditions under which the force remains constant.
jennaskim
The figure(Figure 1) shows the velocity graph of a 2.5object as it moves along the x-axis.
What is the net force acting on this object at t=7 ?
The attempt at a solution
Since F=ma, I tried first finding a by dividing 6 m by 7 s. Then I got 0.857 m/s2 x 2.5 kg = 2.1429 ≈ 2.1 ...but it's wrong :(
Please help.
What you need to do is plot acceleration on the same graph. Acceleration = ax*dvx/dt. So at first the particle accelerates positively a certain amount (how much?), then stops accelerating, then accelerates negatively another certain amount (again, how much?).
Now, keeping in mind Fx = max, read off ax on your newly created chart and use this formula.
What comment might you have regarding the ax graph for x < 6 s?
I got a= -2 at t = 7.
I did F = 2.5 x 2 = 5.0 ...It's still wrong
How did you get a = -2 at t = 7? That's really off.
Nevermind. I think it's a = 6? I took the slope = 12 / 2 = 6
correction: -6 ?
I used a = -6, and i got the right answer! Thanks for you help
Force is a change in momentum, the momentum changes for the first 3s and the last 2s - The force is constant since the decrease in velocity is linear. Find the change in velocity over the period of time when you know the momentum is changing, then you get the force. You know this is exact since the change in velocity throughout each time period is constant (not changing) - i.e. it is not an approximation.
  • · Replies 21 ·
  • · Replies 41 ·
