Period of Red Planet: Find Average Yearly Period
  • Thread starter Thread starter dalitwil
    Period Planet
The discussion revolves around determining the period of a red planet based on its average distance from the sun, in comparison to a blue planet with a known period and distance. The context involves celestial mechanics and Kepler's laws of planetary motion.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the relevance of the blue planet's data, with some suggesting to eliminate constants in the equations. Others reference Kepler's Third Law and discuss the proportionality of periods to the cube of the semi-major axis.
Participants are actively engaging with the problem, discussing different interpretations of how to apply Kepler's laws. Some have suggested that a proportional relationship can be used to relate the two planets, while others are questioning how to incorporate the given data effectively.
There is uncertainty regarding the necessity of using specific values for gravitational constants and the mass of the sun. Participants are also considering how to appropriately apply proportionality in the context of the problem.
dalitwil
In the figure the blue planet has a period of 1 year and an average distance from the sun of 1.73 x 1011 meters. If the average distance from the sun for the red planet is 1.39 x 1011 meters, what is its period to the nearest hundredth of a year?
So I thought maybe they through in the information on the blue planet to confuse me, so disregarding that information, I used the formula:
T=(2pi/square root of GM)*r^3/2
where G=6.67e-11 and M is the mass of the sun=2.0e30kg
Unfortunately, this isn't correct, and I don't see where I am supposed to incorporate the information about the blue planet with the red planet.
Maybe you are not supposed to use the values for M and G in this problem. Just write the expressions of T for the two planets and eliminate [tex]\sqrt(GM)[/tex].
Kepler's Third Law!
Did you learn Kepler's Law? All you need is a proportionality.
Right, the period T is proportional to r^3/2 (Kepler's 3rd law), but I am still unsure how to relate the two planets using this concept.
If
[tex]x^m \propto y^n[/tex]
then, if you have two systems that fit the proportionality:
[tex]\frac{x_1^m}{x_2^m}=\frac{y_1^n}{y_2^n}[/tex]
This applies to all values of m and n.
Proportionality just implies that there is some constant out front. If you have a test case with which to determine that constant, that's all you need.
T^2/a^3=const for all planets orbiting the same massive object.
10K
