New Reply
Value of the constant in 'variation of refractive index'
Share Thread Thread Tools
Mar17-13, 09:52 PM   #1
In optics, given the below formula
nλ= A + B/λ2 + C/λ4 +......
where A, B and C are constants.
From the above relationship we can deduce that as the wavelength λ increases, the variation of refractive index nλ decreases.
How do we measure the constant value of A,B and C at the first place?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Study provides better understanding of water's freezing behavior at nanoscale
>> Iron-platinum alloys could be new-generation hard drives
>> Promising doped zirconia
Mar18-13, 02:42 AM   #2
Recognitions:
You measure the refractive index at several wavelengths and then you fit the formula to the values obtained.
Mar29-13, 04:30 AM   #3
Thank You DrDu.
While the above formula is for Optical Dispersion, then is it the same dispersion for the Abbe Number:
Vd=(nD-1)/nF-nC
where nF-nC is the dispersion according to this link http://glassproperties.com/abbe_number/
but somehow on other link I read that nF-nC is called Principal Dispersion. I try to search on more about Principal Dispersion but there is almost none explanation about it.
Mar29-13, 05:30 AM   #4
Recognitions:
n_F is the index of refraction for blue light while n_C is for red light (see the table with the line frequencies).
One assumes that for glass the dispersion is approximately linear over the optical frequency range.
Mar29-13, 08:27 AM   #5
I understand about the line frequencies. Just that is it n(lambda)=n_F - n_C ?
Mar29-13, 09:27 AM   #6
Recognitions:
I would try something like ## n(\lambda)=n_C+(n_F-n_C)\frac{1/\lambda_C^2-1/\lambda^2}{1/\lambda_C^2-1/\lambda_F^2} ##.
New Reply
Tags
glass, optics, refractive index
Thread Tools
Similar Threads for: Value of the constant in 'variation of refractive index'
Thread Forum Replies
dielectric constant refractive index relationship General Physics 3
refractive index Introductory Physics Homework 5
Refractive index of gold? (& negative refractive index, + surface plasmon resonance?) Atomic, Solid State, Comp. Physics 3
optics: refractive index and dielectric constant Classical Physics 4
refractive index & dielectric constant Introductory Physics Homework 1
