Understanding Electromagnetic Transitions: |ΔI|=1, ΔIz=0
  • Context: Graduate
  • Thread starter Thread starter LayMuon
    Electromagnetic
The discussion revolves around the understanding of electromagnetic transitions characterized by the quantum numbers |ΔI|=1 and ΔIz=0. Participants explore the implications of these transitions in the context of hadronic electromagnetic currents, symmetry transformations, and the properties of intermediate states in particle physics.
  • One participant presents the electromagnetic current as a combination of scalar and iso-vector components, suggesting that this decomposition reflects conservation laws related to baryon number and iso-spin.
  • Another participant questions the significance of ΔIz=0 and seeks clarification on the types of transitions being discussed.
  • A further response elaborates on the symmetries of the quark iso-doublet, detailing how these symmetries lead to conserved currents and charge relations, while also outlining properties of intermediate states relevant to hadronic collisions.
  • Participants express uncertainty about specific aspects of the transitions, particularly regarding the implications of the zero value for I3 and the nature of the transitions themselves.
Participants do not reach a consensus on the interpretation of ΔIz=0 or the types of transitions involved. Multiple viewpoints and questions remain unresolved throughout the discussion.
Some participants express uncertainty about their understanding of the subject, indicating potential gaps in knowledge or assumptions that may affect the discussion. The properties of intermediate states and the implications of symmetry transformations are highlighted but not fully resolved.
LayMuon
We know that electromagnetic current can be written as [tex]j^{\mu}_{em} = \frac{1}{6} \bar{Q} \gamma^\mu Q + \bar{Q} \gamma^\mu \frac{\tau^3}{2} Q[/tex] where [itex]Q = \begin{pmatrix} u \\ d \end{pmatrix}[/itex]. We say this induces a transition with [itex]|\Delta I|=1, \Delta I_z =0[/itex]. What should we understand under that last statement? How do we see that?
It means that the hadronic em-current (to lowest order in e) contains a part which transforms like a SCALAR ( iso-scalar, [itex]I = 0[/itex]) under [itex]SU(2)[/itex] and a part which transforms like the 3rd component of an ISO-VECTOR ([itex]I = 1 , I_{ 3 } = 0[/itex]):
[tex] J^{ \mu }_{ \mbox{ em } } ( x ) = J^{ \mu }_{ \mbox{ em } , I = 0 } ( x ) + J^{ \mu }_{ \mbox{ em } , I = 1 , I_{ 3 } = 0 } ( x ) [/tex]
or
[tex] J^{ \mu }_{ \mbox{ em } } ( x ) = S^{ \mu } ( x ) + V^{ \mu }_{ 3 } ( x )[/tex]
The two pieces are separately conserved, reflecting conservation of Baryon number and 3rd component of iso-spin. Indeed, it is easy to see that
[tex] I^{ 2 } V^{ \mu }_{ 3 } ( 0 ) | 0 \rangle = I_{ i } [ I_{ i } , V^{ \mu } ( 0 ) ] | 0 \rangle = \epsilon_{ i k 3 } \epsilon_{ i k l } V^{ \mu }_{ l } ( 0 ) | 0 \rangle = 2 V^{ \mu }_{ 3 } ( 0 ) | 0 \rangle .[/tex]
This means that [itex]V^{ \mu }_{ 3 } ( 0 ) | 0 \rangle[/itex] is an eigenstate of [itex]I^{ 2 }[/itex] with eigenvalue [itex]1 ( 1 + 1 ) = 2[/itex], i.e. the iso-vector part of the hadronic em-current connects the vacuum to states with [itex]I = 1 , I_{ 3 } = 0[/itex].
I leave you to conclude that
[tex] I ( I + 1 ) \langle 0 | S^{ \mu } ( 0 ) | I , I_{ 3 } = 0 \rangle = 0 ,[/tex]
which means that the iso-scalar part of the em-current, only connects the vacuum to states of total iso-spin zero.
Good luck
Sam
Thanks for reply.
Why I3 is zero? What type of transitions should we understand? Why is there Delta?
LayMuon said:
Thanks for reply.
I don’t understand what you mean by “what type of transitions”. I also don’t know how much you know about the subject. However, I can tell you what you need to know.
The Lagrangian of the quarks iso-doublet has three symmetries:
i) The invariance under a simultaneous phase change of the up and down quark fields, [itex]U_{ B } (1)[/itex], given by
[tex]\delta \Psi = - i \alpha \Psi ,[/tex]
leads to the conserved current
[tex]S^{ \mu } ( x ) = \bar{ \Psi } ( x ) \gamma^{ \mu } \Psi ( x ) ,[/tex]
and to the constant charge
[tex] B = \int d^{ 3 } x \ S^{ 0 } ( x ) = \int d^{ 3 } x \ \left( u^{ \dagger } (x) u ( x ) + d^{ \dagger } ( x ) d ( x ) \right) ,[/tex]
which we call the Baryon Number.
ii) The invariance of the theory under iso-spin transformations, [itex]SU( 2 )[/itex],
[tex]\delta \Psi = - i \vec{ \beta } \cdot \frac{ \vec{ \tau } }{ 2 } \Psi ,[/tex]
leads to the conserved isotopic spin current
[tex]\vec{ J }_{ \mu } ( x ) = \bar{ \Psi } ( x ) \gamma_{ \mu } \frac{ \vec{ \tau } }{ 2 } \Psi ( x ) .[/tex]
Its associated constant charges (iso-vector) are given by
[tex] T^{ a } = \frac{ 1 }{ 2 } \int d^{ 3 } x \Psi^{ \dagger } ( x ) \tau^{ a } \Psi ( x ) .[/tex]
iii) The invariance under [itex]U_{ em } (1)[/itex] transformation, given by,
[tex] \delta \Psi = - i \epsilon ( \frac{ I }{ 6 } + \frac{ \tau^{ 3 } }{ 2 } ) \Psi ,[/tex]
gives us the conserved electromagnetic current
[tex]J_{ em }^{ \mu } = \bar{ \Psi } \gamma^{ \mu } \left( \frac{ I }{ 6 } + \frac{ \tau^{ 3 } }{ 2 } \right) \Psi .[/tex]
This can be written as
[tex]J_{ em }^{ \mu } ( x ) = \frac{ 1 }{ 6 } S^{ \mu } ( x ) + J^{ \mu }_{ 3 } ( x )[/tex]
Integrating the time component of this current leads to the well-known relation
[tex]Q_{ em } = \frac{ B }{ 6 } + T_{ 3 } .[/tex]
In order to study the collisions of hadrons, we need to know the properties of all possible intermediate states. Therefore, we are led to consider the matrix elements [itex]\langle 0 | J_{ em }^{ \mu } ( 0 ) | n \rangle[/itex], where [itex]| n \rangle[/itex] is a set of ( small mass) intermediate states. From the properties of the vacuum, [itex]| 0 \rangle[/itex], and [itex]J_{em}^{ \mu }[/itex] (under the above symmetries), we can prove the following properties of [itex]| n \rangle[/itex]:
1) [itex]| n \rangle[/itex] has zero electric charge and zero Baryon number.
2) [itex]| n \rangle[/itex] is an eigenstate of the charge conjugation operator [itex]C[/itex], with eigenvalue [itex]C = - 1[/itex].
3) The total angular momentum and parity ([itex]J^{ P }[/itex]) of [itex]| n \rangle[/itex] is [itex]1^{ - 1 }[/itex].
4) The total isotopic spin of [itex]| n \rangle[/itex], [itex]T[/itex], is either [itex]0[/itex] or [itex]1[/itex].
Try to prove these properties yourself. If you got stuck on any one, you can ask me for help.
Regards
Sam
thanks.
  • · Replies 24 ·
