Can the Fredkin Gate be Proven to be Reversible and a Universal Classical Gate?
The discussion revolves around the nature of quantum gates compared to classical gates, specifically focusing on the Fredkin gate and its properties of reversibility and universality as a classical gate. Participants explore concepts related to quantum computing, superposition, and the implications of these properties in computational contexts.
  • Homework-related
  • Some participants describe quantum gates as foundational elements of quantum computers, capable of performing calculations much faster than classical computers for specific problems.
  • There is a discussion about the difference between classical bits and qubits, with emphasis on the superposition of states in qubits, which allows for parallel computation.
  • One participant notes that measuring a qubit collapses its superposition, losing the benefits of quantum parallelism, and suggests exploring mutual connections between terms in superposition instead.
  • A question is raised regarding the possibility of performing operations on a quantum system without disturbing it, referencing Deutsch's algorithm as a potential solution.
  • A participant expresses a specific problem related to demonstrating the reversibility and universality of the Fredkin gate, seeking assistance from others.
Participants express differing views on the nature of quantum gates and their implications, with no consensus reached on the specific properties of the Fredkin gate or the effectiveness of Deutsch's algorithm in addressing the posed problem.
Some discussions involve assumptions about the nature of quantum measurements and the implications of superposition, which may not be fully resolved. The exploration of the Fredkin gate's properties remains open-ended.
Individuals interested in quantum computing, the properties of quantum gates, and the theoretical underpinnings of classical and quantum computational models may find this discussion relevant.
H-bar None
How do quantum gates work and how our they different than classical gates?
Quantum gates would be the building blocks of quantum computers, and they could
theoretically calculate much faster than an ordinary computer for certain types of
arithmetic problems.
Crudely put, the idea is that a quantum system can achieve calculation with the
wavefunction in the "wave" mode rather than the "particle" mode. Wave phenomena
are inherently "parallel" when used as a computational tool, so you'd be doing lots
of "work" in a single computational step.
Imagine that you have a computer with a large number in it. You want to divide that
number by all the numbers from 1 to 1e100 to find the one that divides into it evenly.
In an ordinary computer, you would essentially try each divisor one after the next.
A quantum computer could in principle try all the divisors simultaneously. You would
make a quantum "measurment" of the result that had no remainder, forcing the one
calculation you wanted to see to become the manifested value.
It is much like an analog computer that solves a fluid dynamics problem by direct
simulation, but in the quantum computing case you still emply the methods of digital
computers and gain parallelism from the indeterminacy of the quantum system.
Well, this is not really accurate. The biggest difference between a qubit and an ordinary bit is the fact that a bit is either 1 or 0. The qubit is a SUPERPOSITION of 1 and 0. So the qubit really is the 'combination' of the two possible bit-states.
The clue in QM-related calculations is the fact that you don't measure one specific qubit because all the information in this massive quantum paralellism would be gone (the superposition is broken). For example, you can 'calculate' a thousand values for any f(x) in just one step. Classically you would need 1000 calculations. Ofcourse you cannot just measure what outcome 926 is
( ie the term on the 926th position in the superposition of |x>|f(x)>).
Well, you can but then all other terms are lost and you have no benefits of the QM-approach compared to the classical one. What you can do is try to figure out mutual connections between the different terms in the superposition, like phase-differences or something like that.
Further info can be found on John Preskill's webpage, just google for his name;;;Also, look up the problem of Deutsch
marlon
I did say it was crudely put.
Thank you for the replies.
make a quantum "measurment" of the result that had no remainder, forcing the one calculation you wanted to see to become the manifested value.
Is there a way to peform the operations without disturbing the system?
Does Deutch's algorithm solve this problem?
hello everyone
I have problem showing that the fredkin gate is reversible and also a universal classical gate.
is there anyone who can help me solve this problem?
  • · Replies 18 ·
