DIY Reverse Heat Pump: Cool a Room with Refrigerant
The discussion centers on the feasibility of creating a DIY reverse heat pump to cool a room using a heat reservoir and an expansion valve. It concludes that while theoretically possible, the method is impractical due to the inability to effectively remove heat from the room when both the heat reservoir and the refrigerant are contained within the same space. The analogy of leaving a refrigerator door open illustrates that this approach ultimately leads to increased room temperature due to energy consumption. A more effective solution involves using a heat exchanger located outside the room, similar to standard air conditioning systems.
  • Understanding of thermodynamics and heat transfer principles
  • Familiarity with refrigeration cycles and components, including expansion valves
  • Knowledge of heat exchangers and their applications
  • Basic electrical knowledge for potential system integration
  • Research the principles of refrigeration cycles and how they apply to heat pumps
  • Learn about the design and function of heat exchangers in HVAC systems
  • Explore the differences between air conditioning systems and DIY cooling solutions
  • Investigate energy efficiency considerations in cooling systems
DIY enthusiasts, HVAC technicians, and anyone interested in understanding or building cooling systems using refrigeration technology.
Cloudzero
I don't know much about the subject, besides some diagrams and youtube vids, so please bear with me. I'm trying to make a reverse heat pump to cool a small room.
If I had a heat reservoir (in a box within the same room) that could increase the temperature/pressure of a refrigerant and then used an expansion valve (restricting the flow of refrigerant) to decrease the pressure of the refrigerant, could I use the heat reservoir to evaporate the refrigerant sending cold air into the room?
If I had a heat reservoir (in a box within the same room)...
If everything is in the room then all you can do is move heat around within the room.
Sure you can devise a way to temporarily pump heat into this box BUT the inside of the box will get hotter and hotter making it harder and harder to pump it in there. In addition more and more energy will leak back out through the (insulated) walls of the box back into the room.
Consider this question...
It's a hot day. Will leaving the refridgerator door open cool the room? In the long term the answer is no. It will actually get hotter. The fridge will consume more electricity which represents more energy coming into the room. Opening the fridge door does not provide a new path for energy to leave the room - so there is a net increase in energy coming into the room.
What you need to do is have one heat exchanger in the room and one outside the room.
or in other words air conditioner. :D
The ones work with the same thing you separate two places and to get the one colder you move the heat to the other , in the AC case the outside environment.
  • · Replies 30 ·
  • · Replies 23 ·
