Transistor LED Circuit with Mobile Sound Control | DIY Guide
  • Thread starter Thread starter asa!!
    Switch Transistor
The discussion focuses on creating a transistor-based LED circuit that utilizes sound from a mobile device to control the LED's state. The proposed solution involves using two cross-connected transistors to form a memory cell that can toggle the LED on and off based on audio input. By employing low-pass and high-pass filters on the audio signal, different tones can be used to generate the necessary base drive signals for the transistors, allowing for dynamic LED color changes in response to the music played.
  • Understanding of transistor switching mechanisms
  • Basic knowledge of audio signal processing techniques
  • Familiarity with low-pass and high-pass filter design
  • Experience with LED circuit design
  • Research transistor switching circuits for LED control
  • Learn about audio signal filtering techniques
  • Explore circuit design for memory cells using transistors
  • Investigate LED color mixing based on input signals
Electronics enthusiasts, hobbyists in DIY projects, and anyone interested in integrating sound control with LED lighting systems.
asa!!
Hi guys, i want to fix a circuit that will use a led and i want to use a transistor as the switch to the led. I would like the base current to be produced by a sound played throug ha mobile. A sound turning the light on and the same or other sound turning it off. No ideas how to do it.Thank you for your help.any ideas are welcomed
asa!
Check out this thread from a couple weeks ago:
https://www.physicsforums.com/showthread.php?t=78945
In my last post at the bottom, I show a circuit that turns on a red or green LED based on the battery voltage (as a low-voltage indication). The two cross-connected transistors at the right would be how you would normally make a small 1-bit memory cell that can turn on an LED in response to something, and then turn it off in response to something else. By turning on one transistor, that shuts off the other transistor.
Now you just need to figure out what you want to do with your input signals to generate the base drives for the two transistors. For example, you could low-pass the music to generate one base drive signal, and high-pass the music to generate the other base drive signal. Then different tones in the music would turn the LED on or off. If you leave two LEDs in the circut like for the low-batt indicator, you'll get a mix of colors based on the music content.
9K
  • · Replies 24 ·
  • · Replies 21 ·
