What is the expression for the magnitude of the horizontal force?
The discussion revolves around finding an expression for the magnitude of the horizontal force acting on a block on a frictionless wedge, ensuring that the block does not slip. The problem involves concepts from dynamics and forces acting on inclined planes.
  • The original poster attempts to relate the acceleration of the block to the horizontal force, questioning how to proceed after establishing that the block and the force must have the same horizontal acceleration. Other participants suggest setting up free body diagrams and applying Newton's second law to analyze forces in both horizontal and vertical directions.
Participants are actively engaging with the problem, with some providing guidance on setting up equations based on free body diagrams. There is a recognition of the need to reconsider the components of forces and the relationship between the blocks' accelerations. The original poster expresses uncertainty about their calculations, indicating ongoing exploration of the problem.
There is mention of the conditions that all surfaces are frictionless, and the need for the blocks to accelerate together. Some participants question the dependence of the final expression on the angle theta, suggesting that this aspect requires further clarification.
aliciaw0
Find an expression for the magnitude of the horizontal force F in the figure for which m1 does not slip either up or down along the wedge. All surfaces are frictionless.
since it has nothing to do with the friction i am thinking that m1 and the force have to have the same acceleration in the horizontal direction for it not to slide up or down, but I am not sure what to do from there?
thanks
Ok this is what i recommend you do. Setup and FBD for the smaller block alone. You should get your sum of forces vectically to equal zero. The horizontal sum of forces on the smaller block must equal its mass multiplied by its acceleration (F=ma). You know the blocks must accelerate together so acc_block = acc_system. Now apply sum(Fext) = m_sys*a_sys.
thanks i tried what you told me too and i think i still might have done it wrong?
f(block1)y: Fn-Fgcos(theta)=0
F(block1)x: Fgsin(theta)=m1a Fgsin(theta)/m1= a
system x: F= (m1+m2) ((m1g*sin(theta)/m1) and they said my answer was wrong because it doesn't depend on theta. so if you know where to go from here it would be helpful! thanksss
The acceleration of the smaller block is purely horizontal, so define your components accordingly. Let the x-axis be horizontal, not down the plane; let the y-axis be vertical, not perpendicular to the plane.
Redo these two equations. The normal force will have both vertical and horizontal components. The weight should be set equal to [itex]m_1 g[/itex].
yay i got it right thankkk you
Y: Fn= (m1*g)/cos(theta)
X: (m1*g*tan(theta))/m1 = a
system: F= (m1+m2) ((m1*g*tan(theta))/m1 ) =]
  • · Replies 30 ·
  • · Replies 17 ·
