Question about Poisseuille's law and blood flow
  • Context: Undergrad
  • Thread starter Thread starter don_anon25
    Blood Flow Law
The discussion centers on the application of Poiseuille's law to blood flow in the coronary artery. The formula for flow rate is established as Q = π*(P1-P2)*R^4/(8nL). The viscosity of blood is determined to be approximately three times that of water, resulting in a dynamic viscosity of μ_blood = 62.76 lb_f sec/ft² or 3.0 x 10^6 cP. The length (L) of the coronary artery is not definitively provided, with suggestions to either leave it blank for flow per unit length or to estimate its value.
  • Understanding of Poiseuille's law and its application in fluid dynamics
  • Knowledge of blood viscosity and its comparison to water
  • Familiarity with the anatomy of the coronary artery
  • Basic mathematical skills for fluid flow calculations
  • Research the specific length of the coronary artery in millimeters
  • Learn about the factors affecting blood viscosity in different conditions
  • Explore advanced applications of Poiseuille's law in medical scenarios
  • Investigate the impact of arterial radius on blood flow rates
Medical students, cardiovascular researchers, and professionals in biomedical engineering focusing on fluid dynamics in biological systems.
don_anon25
I know that rate of flow is equal to pi*(P1-P2)*R^4/8nL. For blood in the coronary artery, I know the pressure drop, and the radius of the artery. What is the viscosity of blood? I can't find this value anywhere! And what value should I enter for L (distance L along a tube)? Is there an actual value somewhere for the length of the coronary artery in mm?
According to this source http://www.usc.edu/dept/biomed/bme403/Section_3/viscosity_of_blood.html
The value is approximately three times that of water. So if I use the dynamic viscosity of water at 20°C as
[tex]\mu_{water} = 20.92 \frac{Lb_f sec}{ft^2}[/tex], that would mean that [tex]\mu_{blood} = 3.0 \mu_{water}[/tex] so...
[tex]\mu_{blood}= 62.76 \frac{Lb_f sec}{ft^2}[/tex]
[tex]\mu_{blood}= 3.0 x 10^6 cP[/tex]
I can't really help you in terms of L in your equation. A couple of options would be to a)Leave L blank and express your answers in flow per unit length (which sounds kind of funny but is technically correct). or b)Make an estimation.
