How to Find Angle BAD & ABC in a Symmetrical Triangle: Helpful Hints"
  • Thread starter Thread starter Natasha1
    Symmetry
The discussion focuses on solving for angles BAD and ABC in a symmetrical triangle ABC, where AB = AC and AD = DB = BC. The solution involves using analytic geometry, starting with a coordinate system where point B is at the origin (0,0) and point C is positioned along the positive x-axis at (c,0). Participants are encouraged to determine the coordinates of other points and derive the equations of the triangle's sides to find the required angles.
  • Understanding of symmetrical triangles and their properties
  • Familiarity with analytic geometry concepts
  • Ability to set up a coordinate system
  • Knowledge of line equations and angle calculations
  • Explore the properties of isosceles triangles in geometry
  • Learn how to derive equations of lines in a coordinate system
  • Study methods for calculating angles using trigonometric functions
  • Investigate coordinate transformations and their applications in geometry
Students studying geometry, mathematics educators, and anyone interested in applying analytic geometry to solve triangle-related problems.
Natasha1
In a triangle ABC, AB = AC and AD = DB = BC. Find the size of the angle BAD? Find the angles of triangle ABC?
Just need a few hints to get this problem started please? :redface:
Natasha: HallsofIvy responded here with most of the solution. I've soft deleted it and will restore it once you have shown some work on this problem.
He used analytic geometry and he started as follows:
HallsofIvy said:
Set up a coordinate system so that the origin is at point B (B is at (0,0))and the positive x-axis is in the direction of C. Call the length of side BC "c" so that C is at (c,0).
You will need to find coordinates of other points and then find equations of the lines that contain the sides of the triangles. Give that a shot and post what you come up with.
  • · Replies 19 ·
  • · Replies 24 ·
