Banked curve involving friction
The discussion revolves around a physics problem related to banked curves involving friction. The original poster presents a scenario where a car navigates a banked curve with a given radius and angle, while also experiencing friction that prevents it from sliding off the curve. They seek to derive an equation that incorporates both the banking angle and the frictional force.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the relationship between the forces acting on the car, including normal force, gravitational force, and friction. They discuss how to derive the maximum speed equation considering friction, and some participants question the validity of certain assumptions, such as the relationship between tangent of the angle and the coefficient of friction.
The discussion is active, with participants providing insights into the mathematical relationships involved. Some have offered guidance on how to manipulate equations to achieve the desired form, while others are questioning specific assumptions and exploring different interpretations of the problem.
Participants note the complexity introduced by the frictional force and the need to consider both horizontal and vertical components of the forces acting on the car. There is an ongoing examination of the mathematical equivalence of different expressions related to the problem.
SeReNiTy
Hi could some of you guys please help me with question, its question 77 in Understand Physics By Cummings.
For those that don't have access to the book its a question dealing with a banked curve with radius R and a angle alpha. Now there is also a friction force stoping the car from sliding of the banked curve, now my question is how do you derive the equation to explain the situation. I know for a normal banked curve without friction the answer is just, Nsin(angle) = m(v^2)/r and Ncos(angle) = mg
So therefore tan(angle) = (v^2)/rg
Now how do you derive the equation is friction is also a force helping the car sliding down, i know the answer is suppose to be vmax = (rgtan(angle + tan^-1(co-efficient of f)))
If the speed of the car is any greater than the speed you calculated without friction, then the car will need an additional friction force to keep it moving in a circle. This force is parallel to and pointing down the slope. You can decompose this force into its horizontal and vertical components. The horizontal component adds to the component of normal force in the horizontal direction, and the vertical component adds to the force of gravity.
Done this, but what i get is this relation:
(Vmax)² = Rg(sinx + (co-eff)cosx)/(cosx - (co-eff)sinx)
Where co-eff = co-efficient of friction for the particular surface. How do i change this equation into the answer which is:
(Vmax)² = Rg(tan(x + arctan(co-eff)))
Back to the question, i was wondering if you can use the identity
tanx = co-effcient of friction
Its just that friction is acting down the plane for this circumstance...if you can then i know that arctan(co-eff) will just be the the angle of the bank. That way it could simplify down to tan2x but this doesn't yield the same answer as tan(x + arctan(co-eff)). Any suggestions guys?
I don't think the statement \tan x = \mu is true. Your equation gr\left(\frac{\sin x + \mu\cos x}{\cos x - \mu\sin x}\right) is mathematically equivalent to gr\tan\left(x+\tan^{-1}\mu \right).
jdstokes said:
I don't think the statement \tan x = \mu is true. Your equation gr\left(\frac{\sin x + \mu\cos x}{\cos x - \mu\sin x}\right) is mathematically equivalent to gr\tan\left(x+\tan^{-1}\mu \right). I'm not sure how to get it into this form, however.
Yes i know that the 2 equations are mathematically equivalent but how do i go from one form to the other? I was thinking \tan x = \mu also because other wise the expression could be simplified to gr\tan\left(2x\right)
You begin with
gr\left(\frac{\sin x + \mu\cos x}{\cos x - \mu\sin x}\right).
Divide the numerator and the denominator by \cos x
gr\left(\frac{\tan x + \mu}{1 - \mu\tan x}\right).
Using the identity
\tan\left(\alpha + \beta\right) = \frac{\tan\alpha + \tan\beta}{1 - \tan\alpha\tan\beta}
you get \alpha = x and \tan\beta = \mu \Rightarrow \beta = \tan^{-1}\mu. The result is
gr\left(\frac{\sin x + \mu\cos x}{\cos x - \mu\sin x}\right) \equiv gr\tan\left(x + \tan^{-1}\mu \right).
\frac{\sin(x) + \mu\cos(x)}{\cos(x) - \mu\sin(x)}=\frac{tan(x) + \mu}{1-\mu \tan(x)}
You know the addition law for the tangent function:
\tan(x+y) = \frac{\tan(x) + \tan(y)}{1-\tan(x) \tan(y)}
Let
y = \arctan(\mu) \rightarrow \mu = \tan(\arctan(\mu))
Replace for mu in your formula and you get the desired form.
ehild
The friction makes it a little more difficult.
The horizontal forces are:
(1)F_{xfriction} = \mu_sF_Ncos\theta
(2)F_{Nx} = F_Nsin\theta
Therefore:
(3)F_Nsin\theta + \mu_sF_Ncos\theta = mv^2/r
One has to look at the vertical components of the forces to find the normal force. These have to sum to zero (since there is no vertical acceleration). The friction force has a downward vertical component and this, together with gravity, equals the vertical component of the normal force:
mg + \mu_sF_Nsin\theta = F_Ncos\theta
So:
(4)F_N = mg/(cos\theta - \mu_ssin\theta)
So substituting into (3):
\frac{mg}{(cos\theta - \mu_ssin\theta)}(sin\theta + \mu_scos\theta) = mv^2/r
(5)v = \sqrt{\frac{rg(sin\theta + \mu_scos\theta)}{(cos\theta - \mu_ssin\theta)}
AM
Thanks to all for helping out, especially to ehlid and Jd for providing the proof for the trig identity.
  • · Replies 19 ·
  • · Replies 20 ·
