Meaning of isomorphism/diffeomorphism ## f: R^n\to M^m##
  • Context: Graduate
  • Thread starter Thread starter shooride
    Map
The discussion centers around the possibility of defining an isomorphism or diffeomorphism map from ## f: R^n \to M^m ##, particularly when the dimension of the domain ##n## is greater than the dimension of the manifold ##m##. The context includes aspects of topology and differential geometry, with references to Riemannian manifolds and algebraic structures.
  • Some participants assert that a diffeomorphism can exist, citing examples like the projection map from ##\mathbb{R}^2## to ##\mathbb{R}##.
  • Others argue that dimension is a diffeomorphism invariant, suggesting that a diffeomorphism cannot exist when ##n > m## due to the implications of the Jacobian and the invariance of dimension.
  • A participant mentions Brouwer's Invariance of Domain theorem, stating that a continuous injective image of an open set in ##R^n## cannot map into ##R^{n-m}## when ##m > 0##.
  • Some contributions clarify that the term "isomorphism" needs specification regarding the algebraic structures involved, as it may not align with diffeomorphism properties.
  • There is a discussion about the relationship between topological equivalence and dimension, with references to homology groups to support claims about the impossibility of homeomorphisms between manifolds of different dimensions.
  • Participants note that while diffeomorphisms provide additional structure compared to homeomorphisms, they still cannot exist between manifolds of differing dimensions.
Participants generally disagree on the possibility of defining an isomorphism or diffeomorphism when ##n > m##. While some assert that diffeomorphisms can exist under certain conditions, others maintain that dimensionality constraints prevent such mappings.
The discussion highlights the complexity of defining isomorphisms and diffeomorphisms, particularly in relation to algebraic structures and topological properties. Several mathematical concepts, such as homology and the Jacobian, are referenced but remain unresolved in terms of their implications for the original question.
shooride
Can one define an isomorphism/diffeomorphism map ## f: R^n\to M^m## when ##n>m##? ##M## is a non-compact Riemannian manifold..
Yes for diffeomorphism. The projection map is a diffeomorphism, eg ##f:\mathbb{R}^2\to\mathbb{R}## such that ##f((x,y))=x##.
What do you mean by isomorphism though? What is the algebraic structure that you are wanting to preserve?
If you define algebraic structures on domain and range, and find an isomorphism, it will not also be a diffeomorphism, because that would make it a homeomorphism, and there is a theorem that a n-dimensional manifold is not homeomorphic to a m-dimensional manifold if ##m\neq n##.
What do you mean, isn't a diffeomorphism invertible? ##p^{-1}(x_0)=(x_0, \mathbb R ) ##.
No, dimension is a diffeomorphism invariant. Take, e.g., the Jacobian to see why this is not possible. Dimension ( I think this is the Lebesgue dimension) is a topological, i.e., homeomorphism - invariant
https://cdn.mathjax.org/mathjax/latest/fonts/HTML-CSS/TeX/png/Main/Regular/085/2212.png?rev=2.5.3
Right you are. I forgot that part. :oops:
In that case there cannot be a diffeomorphism.
Edit: Ah, as I see you have noted in your next post.
No problem, Andrew, I have made a few of those -- just hit the delete button, and I will delete my post; let me know.
A key theorem that answers this question is Brouwer's Invariance of Domain which says that a continuous injective image of an open set of Rn into Rn is an open subset of Rn and that the mapping is a homeomorphism. It is not hard to show as a corollary that there is no continuous injection of Rn into Rn-m m>0. A differential map is continuous so the theorem applies to differential maps as well.
BTW: This question is really a question about topology not differential geometry.
lavinia said:
A key theorem that answers this question is Brouwer's Invariance of Domain which says that a continuous injective image of an open set of Rn into Rn is an open subset of Rn and that the mapping is a homeomorphism. It is not hard to show as a corollary that there is not continuous injection of Rn into Rn-m m>0. A differential map is continuous so the theorem applies to differential maps as well.
But if you're dealing with diffeomorphisms, you can use tools not available with topology alone: a diffeomorphism gives you a vector space isomorphism between tangent spaces at a point and at its image. By properties of linear maps, both dimensions are the same. OF course, a homeomorphism does not exist either, by, e.g.,as you stated, invariance of domain. You can twist this using the result that continuous bijection between compact and Hausdorff is a homeo. Consider the closed unit ball B(0,1).Then f: B(0,1)--> f(B(0,1)) is a homeo. Now consider a small open disk in B(0,1), which is sent to an open set in R^n , contradicting Invariance of Domain.
That is true.
By properties of linear maps, both dimensions are the same. en set in R^n , contradicting Invariance of Domain.
Not sure what you mean here.
Actually, any two manifolds that are topologically equivalent* must have the same dimension, so the answer here is No.
Possibly the simplest proof of this uses homology, which is a way of assigning one abelian group Hk(X) — which can at times be the trivial group {0} — to each topological space and choice of positive integer k, in such a way that topologically equivalent spaces have isomorphic groups. A mild generalization of this idea assigns an abelian group, likewise, to every pair of topological spaces (X,A) where A is a subspace of X, and every positive integer k. (This is called a relative homology group.)
Then if M and N are topologically equivalent manifolds, there must be a homeomorphism h: M —> N. This implies that for any point p of M, the relative homology groups Hk(M,M-p) and Hk(N,N-h(p)) are isomorphic.
If the dimensions dim(M) and dim(N) were not equal, let's assume, without loss of generality, that d = dim(M) > dim(N). It can be shown that for any manifold M of dimension d, the relative group Hd(M,M-p) is isomorphic to the group ℤ of integers. It can also be shown that for any manifold N with d greater than the dimension of N, the homology group Hd(N,N-q) is the trivial group {0}, where q is any point of N.
But if M and N were homeomorphic they would have isomorphic relative groups. Since they do not, this shows that any two manifolds of unequal dimensions cannot be homeomorphic.
____________
* Note: Two smooth manifolds might be "homeomorphic" (topologically equivalent) or even diffeomorphic (having a smooth homeomorphism between them, with a smooth inverse) but the word "isomorphic" is not used for topological spaces.
____________
I was trying to avoid (co)homology; I thought if the OP was familiar with them, s/he would not have asked the question. And I guess you could also use (c0)homology of the whole space , so that if M>N , then , if M is orientable, its highest homology, say m is, as in the case of the relative homology you used ## \mathbb Z ## , while, again as you said, the m-th homology (and anyone larger than Dim N) would be 0.
I would also tend to avoid purely topological explanations. While they have wider application, they can be much more abstract and conceptually demanding. If the context is Riemannian manifolds, there's no need for them.
Indeed, my current feeling is that homology theory is the most abstract topic in mathematics I have studied. I love it, but to me it seems much less intuitive than diffeomorphisms between Riemannian manifolds, which are quite visual. One of the amazing things about homology theory is that one can achieve such practical, intuitive results, using such abstract mathematical structure, and that there is at present no easier known way to achieve such results. So it's not just abstruseness for the sake of abstruseness, as some branches of mathematics sometimes appear to be.
actually I can define a diffeomorphism between any two manifolds, it is a differentiable map with a differentiable inverse. I just can't prove one exists.
I recommend that you close your eyes when coming upon a topological explanation. Comparing diffeomorphisms with homology groups is like saying you like beautiful landscapes more than GPS devices. (Translation: You can't prove much with just a diffeomorphism. )
And as for "If the context is Riemannian manifolds, there's no need for them," just maybe you don't know all the ways that topological explanations can provide useful information in that context?
The manifolds may not be compact so highest homology may be zero For instance the homology of Rn is zero in all positive dimensions.
But Hn(M,M-p) = Z for any n manifold. This follows from excision.
Let A be an open neighborhood of p that is homeomorphic to an open ball in Rn. By excision,
Hq(M,M-p) = Hq(M-(M-A)),M-p-(M-A)) = Hq(A,A-p) for all q including n. A is contractible and A-p deforms onto a sphere so the exact sequence of the pair (A,A-p)
... Hq(A) -> Hq(A,A-p) -> Hq-1(A-p) -> Hq-1(A) ...
is
0 -> Hq(A,A-p) -> Hq-1(Sn-1) -> 0 except when q = 1.
To say that there is no need for topological proofs when one is dealing with smooth manifolds ignores much of the research in mathematics that deals with the interplay between algebraic topology, differential topology, and differential geometry.
BTW: A Riemannian manifold refers to a smooth manifold together with a Riemannian metric. Your question does not involve a Riemannian metric and is not a question about Riemannian geometry. It is a question about topology. WWGD's proof uses calculus on manifolds not Riemannian geometry. It is a differential topology proof. Zinq's proof is an algebraic topology proof.
But if it is not possible to do it without a Riemannian metric, it is not possible to do it with one. So the Riemannian condition is somewhat superfluous. Is there some result that an n-dimensional Riemannian manifold cannot be equivalent to an m-dimensional one that only uses properties of the metric?
One point that should be made here is that smooth manifolds may be topologically equivalent but not diffeomorphic. For such manifolds, as mathwonk pointed out, it is possible to define smooth equivalence but not possible find one.
The moral is that equivalence is relative to the category of mathematical objects. In the smooth category equivalence means diffeomorphic. In the topological category it mean homeomorphic. In the PL category it means piecewise linearly isomorphic.
I guess the standard example of homeo but not diffeo is that of ## \mathbb R ## and ## (x,x^3): x \in \mathbb R ##.
all connected closed smooth 1 manifolds are either diffeomorphic to R or to the circle.
But the map f: ##\mathbb R \to \mathbb R ## given by ## f(x)=x^3 ## is not a diffeomorphism; the inverse map is not differentiable at 0. I think that the differentiable structures are equivalent, but this is not a diffeomorphism.
As for examples of smooth manifolds that are homeomorphic but not diffeomorphic:
The history of this is very interesting. It was not suspected that homeomorphic smooth manifolds might not always be diffeomorphic until 1956, when quite by accident John Milnor discovered that the 7-sphere S7 (the unit sphere in 8-dimensional euclidean space R8) as a topological space can be given a non-standard differentiable structure — also known as a smooth structure — for which there is no diffeomorphism with the standard S7.
(In fact it turns out that there are exactly 15 distinct smooth structures on S7, where two structures are called "distinct" if there is no diffeomorphism between them. If all smooth structures on a given topological manifold are diffeomorphic, the structure is called "unique".)
It is known that there is a unique smooth structure on S1, S2, S3, S5, S6, S12, and S61. At present, no other-dimensional spheres are known to have a unique smooth structure — so having "exotic" smooth structures is overwhelmingly more the rule than the exception for spheres.
The most pressing problem in differential topology today is whether the 4-sphere S4 has any exotic smooth structure. Surprisingly, this has turned out to be the most difficult dimension to deal with.
The history of this is very interesting. It was not suspected that homeomorphic smooth manifolds might not always be diffeomorphic until 1956, when quite by accident John Milnor discovered that the 7-sphere S7 (the unit sphere in 8-dimensional euclidean space R8) as a topological space can be given a non-standard differentiable structure — also known as a smooth structure — for which there is no diffeomorphism with the standard S7. (In fact it turns out that there are exactly 15 distinct smooth structures on S7, where two structures are called "distinct" if there is no diffeomorphism between them.)
It is known that there is a unique smooth structure on S1, S2, S3, S5, S6, S12, S61. At present, no other-dimensional spheres are known to have a unique smooth structure — so having "exotic" smooth structures is overwhelmingly more the rule than the exception for spheres.
I think 4 is special because it is large enough to allow for bizarreness but not so large so that bizarreness can be done away with, e.g., Whitney trick.
WWGD, your statement in post #21, amounts to saying that projection of the graph {(x,x^3), all real x} onto the y-axis is not a diffeomorphism. Projection onto the x-axis however is a diffeomorphism.
But don't we need both to be diffeomorphisms to have the map from ## \mathbb R ## to itself to be a diffeomorphism?
Here is a hint.
You have given the real line two differentiable structures. The first is the maximal atlas of charts compatible with the identity map - viewed as a chart.
The second is the maximal atlas of charts compatible with x -> x^1/3.
- Show that these two structures are different. This means that the two atlases are not compatible with each other.
- Show as mathwonk said that the two structures are diffeomorphic and that x -> x^3 is in fact a diffeomorpism from the first structure to the second.
So two different differentiable structures can still be diffeomorphic. On the 7 sphere they are not only different but they are also not diffeomorphic.
yes the map from R to itself defined by x-->x^3 is not a difeomeorphism, or equivalently the map from R to itself defined by composing the maps x-->(x,x^3)-->x^3 is not a diffeomorphism. Thus this is indeed an example of a homeomorphism that is not a diffeomorphism. The first map x-->(x,x^3) however is a difeomorphism.
Thus the set of points {(x,x^3), all real x} is not an example of a manifold that is homeomorphic but not diffeomorphic to R, i.e. it is diffeomeorphic to R. That means not that there cannot be a map between them which is a homeomorphism and not a diffeomorphism, rather it means that there is some map which is a diffeomorphism. So even if there is a map which is a homeomorphism and not a difeomeorphism, as long as there is another map which is a diffeomeorphism, then the two manifolds are diffeomeorphic. So it is possible for two diffeomorphic manifolds to admit one map which is a siffeomorphism, and also admit another map which is a homeomorphism and not a diffeomorphism.
The projection map (x,x^3)-->x^3 is a homeomorphism and not a difeomorphism (to the y axis), but the projection map (x,x^3)-->x, is a diffeomorphism from the graph {(x,x^3) all x in R} to the x axis, with inverse diffeomorphism the map x-->(x,x^3). I.e. the map x-->(x,x^3) has two coordinate functions, both differentiable, hence it is differentiable, and the projection (x,x^3)-->x is the restriction of a linear map hence also differentiable.
Lavinia's point is different, that there is a diffeomorphism from the usual structure on R to the one given by composing with the homeomorphism x-->x^3. This is even more interesting.
lavinia said:
Here is a hint.
EDIT: So two different differentiable structures can still be diffeomorphic. On the 7 sphere they are not only different but they are also not diffeomorphic.
I understand, I am aware of the existence of a unique maximal differentiable structure for the Reals, that the two structures are diffeomorphic .I was mentioning that while the differentiable structures are diffeomorphic, I believe, this map is not a diffeomorphism. This is all I meant.
your post "I guess the standard example of homeo but not diffeo is that of R and (x,x3):x∈R." does not complete the words homeo and diffeo to morphic or morphism, but since you gave examples of manifolds and not maps it seems natural to assume you meant homeomorphic and not diffeomeorphic. and that is incorrect.
How so? I never claimed the two were not homeomorphic. I only said, or t least meant to say that the map is not a diffeomorphism. This is correct.
  • · Replies 20 ·
  • · Replies 36 ·
