Gravitational effect of a black hole based on distance
The discussion revolves around the gravitational effects of black holes compared to non-black-hole objects of the same mass, particularly focusing on the distances at which these effects become indistinguishable. The scope includes theoretical considerations from general relativity and gravitational physics.
  • Some participants propose that at large distances, the gravitational effects of a black hole are indistinguishable from those of a star or other massive body of the same mass.
  • Others argue that at close distances, significant differences arise, such as the existence of the photon sphere at 1.5 times the Schwarzschild radius, which does not exist for non-black-hole objects.
  • One participant suggests that for a neutron star, gravitational effects become indistinguishable from a black hole at distances greater than the neutron star's radius, due to the presence of matter in the neutron star that is not present near a black hole.
  • Another participant states that at distances greater than the radius of a non-black-hole object, such as the Sun, the gravitational effects are the same as those of a black hole of equivalent mass.
  • Some participants emphasize that gravity behaves the same for any massive object at large distances, but distinctions arise at smaller distances, particularly near the Schwarzschild radius.
  • There is a discussion about the stability of non-black-hole objects with mass equal to that of a black hole and their potential to exhibit similar gravitational effects.
  • One participant provides a mathematical perspective on gravity in general relativity, discussing the role of the metric tensor and its implications for objects like white dwarfs, neutron stars, and black holes.
Participants express differing views on the specific distances at which gravitational effects become indistinguishable. While some agree that at large distances the effects are similar, others emphasize the importance of proximity to the Schwarzschild radius and the unique characteristics of black holes.
Participants note that the discussion is complicated by the presence of matter in non-black-hole objects and the implications of general relativity, which may not be fully resolved in the context of the questions raised.
Gerinski
Hi,
I have often read that at large enough distances, the gravitational effect of a black hole is no different than the gravitational effect of a star or other body of the same mass.
But that at close distances the difference shows up, for example the notion of the photon sphere at 1.5 times the Schwartschild radius which does not appear for non-black-hole objects.
At which distance precisely do the gravitational effects of black holes become undistinguishable from the effects of a non-black-hole object of the same mass, and why?
TX !
Astronomy news on Phys.org
Hi Gerinski:
I confess that I am not a GR expert, but I will share what I believe I understand about this question.
Massive bodies that are not black holes occupy a much larger volume that a black hole of the same mass. The smallest such bodies are neutron stars, although I understand that the smallest black holes previously detected are much more massive than a neutron star. In principle though it is possible for a black hole to have the mass as small as that of a neutron star. One possible interpretation of your question could be that for a mass equal to that of a neutron star, at distances greater than the radius of a neutron star the gravitational effects are indistinguishable from a black hole. For this interpretation, the reason why it is unreasonable to compare conditions at a smaller distance is that for the neutron star there is matter present which is not present near a black hole.
If you would post a specific different interpretation of your question, I will try to answer that interpretation also.
Regards,
Buzz
Buzz Bloom said:
Hi Gerinski:
Regards,
Buzz
Thanks Buzz B,
I clearly understand that at distances smaller than the physical boundary there are distinguishing effects. The Sun has a certain radius, and a black hole of 1 Sun mass has a much smaller (Schwardschild) radius, so in all the distance scales between the 1 solar mass black hole radius and the actual Sun's radius the gravitational effects differ.
So my question goes like, in this precise case for example, at which distances from the center of such a 1 solar mass black hole or the actual Sun, would the gravitational potential characteristics become indistinguishable from each other.
Hi Gerinski:
At distances greater than the sun's radius, say R, (ignoring the sun's rotation and oblateness which makes sun's shape not quite a sphere), there is no gravitational difference between the sun and a BH of the same mass. At a radius r < R the gravitational effects are completely different. A major reason why this is so is that the sun's mass in the spherical shell between r and R has no gravitational effect on a particle at radius R.
Regards,
Buzz
I would say that the distance where a black hole is noticeably different from a non black hole would be the Schwartschild radius itself! Otherwise, gravity is gravity. It works the same for everything.
If you are external to the massive object, you experience it's gravity as a force pulling you towards where the center of it's mass is..
The closer you get to the center of the mass the stronger the gravity is.
Whether the massive object is a black hole or a star or something else makes no difference, the gravity field for a given mass will be the same.
Hi russ:
Your statement is of course correct, but but I think my interpretation of Gerinski's original question is different than yours. I may be wrong, but I think Gerinski question was seeking a description of the nature of a some specific non-BH object with the same mass as a BH, and with respect to those two objects, a radius which could be clearly defined separating BH gravitational effects from non-BH gravitational effects.
Applying this idea to your statement, suppose we consider a BH of mass M, and Schwartschild radius r. Now consider a non-BH object of mass M and radius, say for example,
R = 1.1 × r.​
Could such an object as this non-BH object possibly be stable? If not, then I don't think it would be a good example to use to answer Gerinski's question. If so, then it would be very strange indeed - a non-BH with photons moving around it in circular orbits with a radius of 1.5 × r.
Regards,
Buzz
The full equation for gravity for a non-(or very slow)rotating, non-charged object in GR is-
g=\frac{Gm}{r^2}\frac{1}{\sqrt{1-\frac{2Gm}{rc^2}}}
where the first part of the equation (Gm/r^2) is an approximation of the stress energy tensor and the second part represents the metric tensor.
Though technically it will always apply, the metric tensor part of the equation can be dismissed when approximating/calculating gravity at the surface of non-relativistic objects such as planets and non-exotic stars. The difference the second part makes becomes apparent when considering the surface of white dwarfs, neutron stars and black holes (note as r approaches 2M (the Schwarzschild radius or event horizon), gravity begins to increase exponentially, becoming infinite at 2M (M=Gm/c2)).
It's also worth noting that the metric tensor produces the time dilation equation, which in the case of a non-rotating, non-charged object is d\tau=dt\sqrt(1-2Gm/(rc^2)).
R = 1.1 × r.​
It's predicted that the smallest radius an object of mass can collapse to before the runaway effect turns it into a black hole is 9/5M which is 2.25M (or 1.125 the Schwarzschild radius) which means technically, some neutron stars can have a photon sphere at 3M.
Consider a hypothetical star and a hypothetical black hole.
The star's mass is 1 zillion kg* and its diameter is one million miles.
The BH's mass is also 1 zillion kg and its diameter is ten miles.
* It doesn't matter, as long as they're both the sameIf you got in your spaceship and brought it to within 500,001 miles of the centre of the star (i.e. one mile above its surface), you would feel the same pull as if you brought it to 500,001 miles above the centre of the BH (i.e.499,996 miles above its Schwartschild radius). So, without windows, you could not tell what body you are hovering near.
Your distance to the surface of an object is irrelevant to its gravitational pull on you; the only relevant distance is to its centre.So now you drop 2 miles closer to the BH, and you are now hovering 499,999 miles from its centre. Gravity increases slightly, as it should.
But if you drop 2 miles closer to the star your're in trouble, because now you're inside the star. Assuming your spaceship can survive, you will still experience a gravitational attraction to the star, but it will actually be less because the outer shell of the star is no longer a gravitational factor.
The point here is that a black hole's gravity is identical in every way to a star's (or any other body's) gravity. The only thing about a black hole is that you can get closer to its centre.
But be clear on this: gravity does not behave any differently around a black hole than anywhere else.
Thanks a lot to all !
  • · Replies 17 ·
  • · Replies 30 ·
  • · Replies 27 ·
