Matlab -- how can i use a FOR loop if I have 2 variables changing
The discussion revolves around the use of a FOR loop in MATLAB when two variables, m and q, are changing. Participants explore the syntax and logic required to implement such a loop, addressing issues related to variable dependencies and MATLAB's loop structure.
  • One participant questions the necessity of including variable m in the loop, noting it is not utilized within that specific context.
  • Another suggests using separate loops for independent variables or making one dependent on the other, providing an example of how to structure the loops based on variable relationships.
  • A participant asks for clarification on what should happen if m and numfeature differ, indicating a potential issue with variable alignment.
  • Several participants discuss the syntax of MATLAB's FOR loop, specifically the use of variables in the initialization, step size, and maximum value, with some expressing uncertainty about the correct usage.
  • There is a consensus among some participants that the syntax attempted by the original poster is incorrect, particularly regarding the inclusion of an assignment within the loop declaration.
Participants express differing views on the correct implementation of the FOR loop syntax in MATLAB, with no consensus reached on the best approach to handle the changing variables m and q.
Limitations include unresolved questions about the relationship between m and numfeature, and the specific requirements for the loop's functionality, which may affect the proposed solutions.
jiaying
Hey,for following code the 3rd loops i need to have 2 variables m and q .Could anyone help?
Matlab:
for t=1:maxiterations
    toterror=0;
    for j=1:numfeature
        totslope=0;
        for i=1:m&&q=1:numfeature
              z=0;
           for jj=1:numfeature
               z=z+prevtheta(jj)*x(i,jj);
           end
           h=1.0/(1.0+exp(-z));
           H=H+(x(i,q)*h*(1-h)*x(i,jj));
           totslope=(totslope+(h-y(i))*x(i,j));
           toterror=(toterror+-y(i)*log(h)-(1-y(i))*log(1-h));
        end
   toterror=toterror/numtrainsam;
   theta(j)= theta(j)-H\totslope;
    end
    prevtheta=theta;
      errorperiteration(t)=toterror/j;
end
I assume you're asking about this loop.
Matlab:
              z=0;
           for jj=1:numfeature
           end
        end
Why is m in there? It's not used in that for loop, and it's not used outside the loop.
In general, you would either use separate loops if they vary independently or make one dependent on the other.
Say m varies from 1 to 10 and n varies from 4 to 40
Then loop on m and compute n = 4*m inside the loop.
What do you want to happen if m and numfeature are not the same value?
It helps if you say in words what you want to do. In MATLAB the syntax for for loop is
Code:
for ii=intialValue: stepSize: maxValue
I don't think you can include a variable in the stepSize option. What do you want to do with this for loop?
I'm fairly certain that you can use variables for all three: initVal, stepVal, and endVal. I don't have matlab, so I can't confirm this.
However, the for loop body can't change the value of the index variable (the loop control variable).
I think you can use variables in the all three, too, but I don't think you can use the following syntax
Code:
initialValue=1;
endValue=10;
for ii=initialValue:m=0.5:endValue
as the OP tried to do.
Code:
initialValue=1;
maxValue=10;
The problem is the "m=" part.
I believe this would be fine:
Matlab:
initVal=1;
stepVal = 0.5
endVal=10;
for ii=initVal : stepVal : endVal
;; loop body
end
