Data Analysis: Observation Model Problem
The discussion focuses on developing an observation model for deducing the unknown masses of three rocks, denoted as ##m_1, m_2,## and ##m_3##, by measuring the weights of two rocks at a time. The observation model is defined as ##z=H\theta+v##, where ##z## is the measurement vector, ##H## is the observation matrix, ##\theta## is the parameter vector, and ##v## represents random additive noise. Two scenarios are analyzed: one with unknown total weight and another with known total weight, highlighting the transition from exact solutions to least squares optimization due to the presence of noise.
  • Understanding of observation models in statistics
  • Familiarity with matrix operations and linear algebra
  • Knowledge of least squares optimization techniques
  • Experience with simulation in programming environments
  • Explore the implementation of least squares optimization in MATLAB
  • Learn about simulation techniques for additive noise in data analysis
  • Study the derivation and application of observation matrices in statistical modeling
  • Investigate methods for solving systems of equations with noise interference
This discussion is beneficial for data analysts, statisticians, and researchers involved in modeling and simulating physical systems, particularly those dealing with measurement errors and optimization problems.
lep11
The task is to write the observation model for the following case: There are three rocks whose unknown masses are ##m_1,m_2## and ##m_3##. You are able to measure the weight of two rocks at a time (not only one and not all three). Can you deduce the unknown masses of the rocks? Simulate the cases when the total weight of the rocks is
a) unknown
b.) known.
Use additive noise in the simulations. What is the difference in the observation models in parts a) and b)?
The observation model will be ##z=H\theta+v##, where ##z## is column vector containing the results, ##H## is the observation matrix, ##\theta## is the parameter vector and ##v## is a vector containing random additive noise.
b.)
In this case ##z##=[1 1 0; 1 0 1; 0 1 1; 1 1 1]*[##m_1## ##m_2## ##m_3####]^{T}##+##v##.
Here's the code I came up with:
Code:
H=[1 1 0;1 0 1; 0 1 1; 1 1 1];% Observation matrix
z=[4.45, 7.35 ,6.8, 10]'; % simulated weights of rock pairs, (I just made them up)
th=inv(H'*H)*H'*z; %solving for m1,m2,m3
It is easy to solve for the masses of the rocks using matrix operations. However, I am not sure how to model the two cases properly. How would one simulate the cases? What if the total weight of the rocks is unknown? Can you please help me with this problem?
P.S. I apologise in advance if this is wrong section for this topic.
Anyone?
Without noise, you get three equations and three unknowns:
m1 + m2 = a
m2 + m3 = b
m3 + m1 = c
This can be solved by any standard method: substitution, elimination, matrix, etc.
Once you add noise, there is not an exact solution. It mostly becomes something like a least squares problem:
minimizing the square error between m1 + m2 and a, m2 + m3 and b, m3 + m1 and c.
  • · Replies 29 ·
